Old 02-02-2004, 12:17 PM   #1
S4Per's Avatar
Question One more time: Will this car adapter work?
Hi All,
To clarify my earlier post: these are the specs of a car ADAPTER which can be used with the PC that I am getting (i.e. it plugs into the power supply). It is sold from the same manufacturer as the PC, so I'm sure it works (generically) in a car, but I know people here know more and can add their opinion. The adapter specs are:
Output Voltage +16V~24V
Output Current 7A Max or 120W Max
Input Voltage DC 11V~16V
Input Current 12A Maximum
Line Regulation 0.5% Maximum
Load Regulation ±5%
Ripple & Noise 300mV Maximum
Efficiency 88% Typical
Temperature Coefficient 0.05%/_
Over-Voltage Protection 28V Maximum
Does that look OK to everyone as far as it hooking into the battery? Any issues with it? Would I need anything else between it and the car?
Thanks in advance,
Per
S4Per is offline   Reply With Quote
Advertisement Sponsored links
Old 02-02-2004, 12:31 PM   #2
NJay's Avatar
With a input voltage of 11V~16V then yes it will work in the car. It might not be enough to keep it running when you crank the engine over the car's electrics drop to less than the 11v minimum input.
What's more interesting is what CarPC you are getting that requires 16v~24v. Please give details.
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 02-02-2004, 12:42 PM   #3
S4Per's Avatar
well, i searched high and low, read all the stuff here for a few weeks, thought about P4 vs. VIA, build my own, etc. and finally just very simply ended up here: http://www.upont.com/latte.asp. I plan on mounting it in the glove box, and should receive it this week. At the site above, under 'Accessories' is where the car adapter is listed.
Thoughts?
Old 02-02-2004, 02:31 PM   #4
NJay's Avatar
Yeah thought as much.
I believe that this is the same manufacturer of the power supply that I'm getting from falken (it sure as hell looks the same too )
The only diff is yours outputs 19v at 3.16A to match the Latte PC whereas mine will output 12v at 5v to match the Morex DC-DC board I have.
VGA to RCA adapter... will this work? 700mx6 Newbie 6 01-10-2004 08:46 PM
found a car adapter for mini itx case! e36mp3 General Hardware Discussion 7 08-04-2002 04:06 PM
car dc adapter problem mr0range Power Supplies 1 11-21-2001 07:58 PM
Portabl MP3 Car Player : Can they work with existing car cd Players? jignesh5 General Hardware Discussion 7 12-29-2000 12:03 PM
playstation in car with an mp3 adapter johnnystorm General Hardware Discussion 7 05-06-2000 03:56 AM
