Notices
Old 02-07-2004, 08:50 AM   #1
Question Epia M10000 Itps Ps-on
Hi,
I have recevied my ITPS and I am in the process of hooking it up to my Casetronic C134 PC.
I have found the +12V supply and the connector is the same type as the ITPS so no problem there, then there is the PS-ON cable from the ITPS, where does that cable go.
I have found a socket that has a lot of wires and one ot these is a green one labeled PS-on. How do I hook up the ITPS ps-on cables (one red and one black) to my EPIA M10000?
Comment would bemuch appreciated!
loscooby is offline   Reply With Quote
Advertisement Sponsored links
Old 02-07-2004, 09:06 AM   #2
Raw Wave
Laidback's Avatar
No, no, no, no, no, no, nooooo! :Shakes head slowly:
Didn't the ITPS come with instructions?
Sounds like you know just enough to be dangerous!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 02-07-2004, 12:27 PM   #3
So, now when Igotyour attention
Since you seem to knowexaclty how the power on on ITPS works with the EPIA M10000 mother-board, please enlighten me.
Just how do you wire the ITPS?
regarding the instructions, NO it did ofcourse not come with an instruction that covers all possible motherboards, that is why I asked this question anyway....
So please if someone can be a bit more constructive that going, no not that way...
Hope to get some constructive wiring instuctions !
Old 02-07-2004, 12:37 PM   #4
Raw Wave
Laidback's Avatar
[quote=loscooby]
QUOTE]
He he, :shakes head again:
I'll give you a clue - ATX
Laidback
Laidback Carputer
Old 02-07-2004, 12:43 PM   #5
none's Avatar
The instructions that come with it DO cover all possible motherboards, they are all the same. If yours didn't come with instructions you should get in touch with whoever you bought it from and get them to send it to you.
The PS-On cable goes from the ITPS "J2" jumper to your motherboard's ATX power switch jumper (you'll have to look at your motherboard's manual to find out where that is.)
none is offline   Reply With Quote
Old 02-07-2004, 12:44 PM   #6
I thought this was a forum to help people
and not to put people down.
I know I do not know how to do this and I did ask for a solution not a riddle.
I was not expecting this type of help, I am mearly looking for a solution to my problem....
So please I do not have time for you showing off with this riddle-game...
Old 02-07-2004, 12:47 PM   #7
thanks 'none'
I appreciate your answer, I have consulted my VIA manual but I have not been able to find any specifics about the matter.
Again thanks for the constructive advice!
Old 02-07-2004, 12:56 PM   #8
none's Avatar
http://www.viavpsd.com/product/3/4/EPIA-M_v1.40.pdf
Page 2-12: Power Switch (PW_BN) pins 6 & 8.
Old 02-07-2004, 01:07 PM   #9
Thanks again 'none'
This is what I was looking for, the manual i got with the board was not this detailed, great!
Old 02-07-2004, 03:10 PM   #10
LESLIEx317537's Avatar
On the ITPS. Any connector with 2 leads goes to the mobo/PS. (obviously the little power switch header goes to the power switch header pin.)
And any connector with 3 leads goes to the power/ground/turn-on lead.
Simple.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Help with Epia 800 / pw60 / ITPS lalo Power Supplies 0 01-04-2004 03:39 PM
v10000 epia vs m10000 epia traitorhound Newbie 1 11-27-2003 10:19 AM
Dual 60W DC-DC PS for Epia M9000 Scafremon Power Supplies 5 03-17-2003 06:48 PM
EPIA M6000 and Opus PS millec Power Supplies 2 01-09-2003 01:12 PM
PS emulation with the c3 800mhz, via epia board ??? zzsprade General Hardware Discussion 8 07-10-2002 01:03 AM
