Old 02-13-2004, 10:13 AM   #1
dbinnc's Avatar
NE1 seen this Pure Sine Wave inverters?
http://www.donrowe.com/inverters/puresine_300.html
Wonder if they are that much better and worth it?
Site dedicated to the 7th Gen Honda Civic
FKA 2k1civic.com
dbinnc is offline   Reply With Quote
Old 02-13-2004, 10:19 AM   #2
Nice.... but the price is so high on it, I don't know.... too bad we couldn't incorporate something like this w/ the OPUS.... that would be worth $200 - $250.00 dollars for the whole raw deal!!!
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 02-13-2004, 11:56 AM   #3
Raw Wave
Confused's Avatar
For inverters, Pure Sine Wave is the best. However, if you're powering a PC, then you still don't want to go from DC-AC-DC. The Opus is still probably the best thing to do.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 02-13-2004, 12:13 PM   #4
owenjh's Avatar
I think with pure sine wave you can power a UPS, if so its shutdown controller could do everything for you just have it connected to the ACC
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Old 02-13-2004, 12:43 PM   #5
MySQL Error
MatrixPC's Avatar
That's good idea.
You can have the UPS software shutdown the computer when AC is removed after xx minutes but then how would you turn the UPS on and off?
I think SDC is still needed.
With the price of a pure sine wave inverter and UPS and installation size, OPUS is much better but it only 150W. dammm.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-13-2004, 08:52 PM   #6
Registered User
Quote: Originally Posted by MatrixPC
That's good idea.
My point exactly. the Opus costs nearly 200 dollars, and ONLY puts out 150W DC. That's why I opted to go with an additional 65AMP alternator for the computer (replacing the AC Compressor), a 300W (rms) Inverter (to 120vac) and then a 450W/700va (volt-amp) APC UPS (APC model SU700-NET, pure sine-wave output, over/under-voltage correction, Power Chute etc). Only problem I have right now is the UPS won't power up in car even when fully charged. I think it has something to do with the "Site Wiring Fault" protection that it has built into it. The "Site Wiring Fault" light comes on, so I think I need to make sure that:
  • All Cases Commonly Grounded (DC->AC Inverter), UPS, & carPC
  • Negative Prong on 120vac is Connected to Common Ground (Car Frame)
If you're not paranoid, then you're not paying enough attention. -kmfdmk.com
http://www.mymp3car.com/MP3Car/PSUpower.asp
1985 Supra 7M-GTE
10.4" Planar LCD
ECS GOAL3+ mobo w/ 512mb + 8GB sdhc
Edimax EW7318USG Wifi w/ 7 db Ant.
USB GPS
kmfdmk is offline   Reply With Quote
FS : 3D Render Card - ART VPS - PURE P1800 PCI ccsnet Classified Archive 2 03-09-2004 08:36 AM
Pure sine wave inverters. worth it? nzKAOSnz Power Supplies 3 10-27-2003 03:48 AM
Different invertor - Via Epia M mag2 Power Supplies 29 06-11-2003 07:15 PM
Is there always a hum in the audio when you use a regular psu w/an inverter? wysiwyg Power Supplies 11 01-13-2003 02:55 AM
sine vs. modified sine wave inverters spitzfan General Hardware Discussion 1 01-05-2000 09:59 PM
