Old 02-15-2004, 08:28 PM   #1
S4Per's Avatar
S4Per is on a distinguished road
Question Power consumption question
Hi All,
I'm trying to figure out how much power my system will consume. One thing I'm fuzzy about: If I have several devices connected to a USB2 hub and the hub is powered off of the car (ignition wire), i.e. it's not bus powered, will this 'count' against how much power my power supply must support? Do I still include the devices in my calculation?
TIA,
Per
S4Per is offline   Reply With Quote
Advertisement Sponsored links
Old 02-15-2004, 09:31 PM   #2
albysure's Avatar
albysure
try this out
http://www.mymp3car.com/MP3Car/PSUpower.asp
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Old 02-15-2004, 09:43 PM   #3
S4Per's Avatar
Thanks, that's what I'm trying to use. It doesn't answer my question.
If the usb hub has power coming to it (wired to car), how do i calculate the power consumption of the devices going to it? Intuitively, I'd say it does not factor into the equation because the power supply won't have to support it - it's already getting power from the car. Can someone confirm, deny?
TIA,
Per
Old 02-15-2004, 10:03 PM   #4
albysure's Avatar
albysure
try powering the hub off the power supply for the computer
Old 02-15-2004, 10:08 PM   #5
none's Avatar
none is on a distinguished road
TIA,
Per
Confirm, the power is coming from elsewhere, won't affect the PSU at all.
Where did you get a hub that uses 12 volt? Or do you have a standalone 5 volt regulator?
none is offline   Reply With Quote
Old 02-16-2004, 05:07 PM   #6
S4Per's Avatar
Don't have either yet Just doing the research...Sorry for the ignorance, but what's involved in getting / making a 5V regulator?
Old 02-16-2004, 06:08 PM   #7
jusatry's Avatar
jusatry is on a distinguished road
i would like to find something like this too....that added power of not needing to power USB could be re-directed to another HD
keep us updated if you find anything.
jusatry is offline   Reply With Quote
Just Cooler RF Remote power switch question swzine Power Supplies 0 11-23-2003 03:14 PM
Question about power and inverters and all that SBmp3 General Hardware Discussion 1 05-01-2003 12:35 AM
DennisK power question Cyanide General Hardware Discussion 15 06-13-2002 09:06 AM
lcd power question jrbless LCD/Display 1 04-07-2002 01:27 PM
Too much power consumption with 300w - Need help wallachee Power Supplies 7 12-31-2001 12:49 PM
