Notices
Old 02-16-2004, 12:02 PM   #1
S4Per's Avatar
Question micro-atx and opus
Can anyone verify that I can use an Opus with a micro-atx mobo and case?
felx atx also?
TIA,
Per
S4Per is offline   Reply With Quote
Advertisement Sponsored links
Old 02-16-2004, 03:32 PM   #2
As long as the mobo uses the standard ATX power connector, it should work fine.
tejesh83 is offline   Reply With Quote
Old 02-16-2004, 04:03 PM   #3
And as long as your power consumption isn't more than what the OPUS is providing.
Almost a Ghost is offline   Reply With Quote
Old 02-17-2004, 02:41 AM   #4
kiztope's Avatar
My Shuttle MN31N also requires a 2x2 12v plug.... Does the opus supply this?/
kiztope is offline   Reply With Quote
Old 02-17-2004, 07:31 AM   #5
Yes, my Opus 150W came with this.
shchua is offline   Reply With Quote
Old 02-17-2004, 07:35 AM   #6
felx atx also?
TIA,
Per
If you're referring to the physical fit, my Opus 150 is an exact drop-in replacement for the PSU in my microATX case, right down to the location of the mounting screws.
Old 02-17-2004, 11:59 AM   #7
kiztope's Avatar
Thanks..... I just got the mobo yesterday, and had no idea it needed this plug! My older atx psu doesn't even have one.... what a relief
Im off to buy a new psu! (so I can set this thing up in the house!)
Old 02-17-2004, 12:05 PM   #8
S4Per's Avatar
shchua - that's what i was referring to. what case are you using btw?
Old 02-18-2004, 01:47 AM   #9
I had no problems fitting the Opus 150 into a Casetek CS-1007-2B case and no-brand microATX case from Taiwan. Something you might want to take note of - the 3 pin Molex connector on the Opus (for +12/GND/Ign) is quite close to the bottom edge. There's a rare chance that on some microATX cases, the Molex connector may run into the bottom lip of the case where the mounting hole is. You might want to test fit the Opus into any prospective case before buying.
OPUS ATX Vehicle Workstation... matx version chenko Newbie 6 01-12-2004 03:36 AM
testing opus outside of car aoLhaTer Power Supplies 3 01-10-2004 04:18 AM
Opus ATX and ITX PSU - Difference? phoTToniq Power Supplies 5 09-22-2003 04:21 AM
New version of Opus ?? cproaudio Power Supplies 3 11-05-2002 04:13 PM
More info on OPUS automotive ATX power supply InvisiBill Power Supplies 3 08-16-2002 03:19 PM
