Notices
Old 02-20-2004, 07:51 AM   #1
GRUNT's Avatar
USB Power
Extracted a 3 port USB powered HUB from an old monitor.
It requires 6.3v.
What is the best way to drop 12v to 6.3v or up 5v to 6.3v
Don't think it will require much amps!
The power supply it used, input is 240v and dose not work.
I have two max788 could I use them?
If yes what is the eased way to connect them?
Thanks for your help.
GRUNT is offline   Reply With Quote
Old 02-21-2004, 07:07 AM   #2
http://www.radioshack.com/product.as...%5Fid=276-1778
It even has schematics on the back- or at least it used to. If it doen't, let me know. I can throw a design together for you.
Just keep in mind I think you can only get ~1A from it, and that's with a heatsink.
droswell is offline   Reply With Quote
Old 02-21-2004, 12:19 PM   #3
GRUNT's Avatar
Thanks Droswell,
Found this link that shows how to use them.
If I understand, When you adjust the resistance on pin (1) this adjusts the output voltage.
With 12v input, min output=1,25v and max output=12v-1,25v.
1,25v=Reference Voltage of the LM317T
http://www.bit-tech.net/article/32/
Old 02-22-2004, 02:17 AM   #4
This will help too
http://ourworld.compuserve.com/homep...den/page12.htm
Gives you the whole diagram
power to USB stays on during hibernate ob1 Power Supplies 14 04-14-2004 10:53 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
USB power & touchscreen issues... Ren77 General Hardware Discussion 1 12-11-2003 05:56 PM
power consumption of a usb hub cubanmoses Power Supplies 2 08-09-2003 02:27 AM
HELP! USB HUB FOR Laptop, how do I power it??? bankingdom General Hardware Discussion 2 05-21-2003 07:33 PM
