The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 02-25-2004, 07:59 PM   #1
ob1
ob1's Avatar
My Photos: (0)
wierd power problem (opus or m10000 prob)
I have an opus 90W powering a M10000. Over the last week, it has been randomly deciding to power up or not power up when i start the car.
Today it wouldn't power up at all - in fact the green status LED was not even blinking. So i checked all wiring, fuses and voltages to find nothing out of the ordinary. I repeatedly unpluged the opus input power cable to attempt to check things and diagnose the problem, but it didn't help.
It wasn't until i unplugged the ATX power cable from the mobo that something must have got "reset" and when it was all plugged back in, it worked - the PC came out of hibernation at the same spot it left off.
I wonder if it was an opus thing or a m10000 problem? I hope it will continue to work now
ob1 is offline   Reply With Quote
Sponsored Links
Old 02-25-2004, 08:21 PM   #2
BoraXP's Avatar
Vehicle: VW Jetta 2k
My Photos: (0)
mobo thing
or maybe a short some where
make sure no bare wires are floating around
or that theres nothing closing a circut
BoraXP is offline   Reply With Quote
Old 03-08-2004, 06:23 AM   #3
ob1
ob1's Avatar
My Photos: (0)
actually turned out to be neither...My main battery fuse (which the opus sources power through) was acting VERY strange. On visual inspection, it was not blown, but anytime any significant amount of current was trying to flow through it, it would act as an open circuit. When the current level dropped, it would be almost like a closed circuit (lke a good fuse should be). Switching on the carPC made it go open circuit....I've never seen a device act in such a non-Ohmic way like this before - made it very hard to diagnose the problem. Must have had a dry/weak solder joint between the fuse wire and the end cap that made it impossible to see it was blown.
The solution was easy though - just replace the fuse!
Old 03-31-2004, 02:14 AM   #4
Vehicle: 1999 Toyota Celica VVTi
My Photos: (0)
Bump.
I seem to be getting the same problem at the moment. My Opus completely shut off last night and won't come back on... no blinking LED or anything. It possibly has something to do with the fact that I dropped the power lead for my Lilliput (powered from the Opus) onto the top of my stereo accidentally when I was fiddling with the screen.. it had a bit of a sparking fit :O Everything seemed to be working perfectly for about 10 minutes, though, when the thing just went off never to come on again
Have tried disconnecting the plug on the Opus, but I'll try disconnecting the ATX plug this evening to see if that helps. Better check all the fuses too
Celica VVTi
EPIA M10000 Nehemiah, 160Gb HDD, 7" Lilliput VGA Touchscreen, Opus 150Watt PSU, Slimline DVD/CDRW, Road Runner
Magma is offline   Reply With Quote
Old 03-31-2004, 01:32 PM   #5
My Photos: (0)
Sorted. My ground wire had managed to come loose.. I've re-soldered it nice and firmly! Panic over
Celica VVTi
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Via Epia M10000 power button LandyLuke General Hardware Discussion 5 02-15-2004 02:46 PM
on board network card problem with m10000 [H]Bugster General Hardware Discussion 10 01-12-2004 05:19 PM
m10000 won't power up swzine General Hardware Discussion 5 11-23-2003 02:49 PM
Wierd Alpine Aux-In Problem CFar General Hardware Discussion 3 02-12-2003 07:56 AM
Wierd problem alexchannell General Hardware Discussion 7 05-13-2002 12:18 PM
Sponsored Links
Ad Management by RedTyger
