The MP3car.com Store
Thread Tools Display Modes
Old 03-02-2004, 01:43 PM   #1
00CericaRuss's Avatar
Vehicle: 2000 Toyota Celica GT-S
My Photos: (0)
opus resistor for low power cutoff?
anyone change this resistor to one that will let your computer run at a lower voltage?
I have an underdriven alt. pulley in my car, and my computer goes into standby when i'm sitting at a light w/too much bass running.
my options as i can see at the moment are:
- change resistor and hope it works
- get capacitor for computer to have more steady power
- put stock alt. pulley back in
Car: 2000 Toyota Celica GT-S
Mods: Yep
Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
00CericaRuss is offline   Reply With Quote
Sponsored Links
Old 03-02-2004, 01:49 PM   #2
Cherub211's Avatar
Vehicle: '04 Pontiac Sunfire
My Photos: (0)
I would put the stock alternator pully back on. You need more electrical power, and the only way you are going to be able to do that is take it from your engine. It's not like you're going to lose all that much HP. Changing the resistor won't help.
Cherub211 is offline   Reply With Quote
Old 03-02-2004, 02:00 PM   #3
Registered User
Sh0cker's Avatar
Vehicle: mk3 GTI VR6
My Photos: (0)
As he said put better alt. back on...if you worry about your HP/speed you should consider driving without extra weight - subs
Danny.
"If today was perfect, there would be no need for tomorrow."
My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
Sh0cker is offline   Reply With Quote
Old 03-02-2004, 02:04 PM   #4
My Photos: (0)
meh.. i just don't want to have to pull the pulley out
but does anybody know of this resistor i speak of?
Mods: Yep
Old 03-02-2004, 02:10 PM   #5
Cherub211's Avatar
My Photos: (0)
If you arn't willing to pull the pully off, go get one of those big @$$ capacitors they sell for audio applications. I would try to do everything else before I change a resistor on something as complicated and expensive as an Opus.
Old 03-02-2004, 03:23 PM   #6
P4_2.66GHz's Avatar
My Photos: (0)
If your system goes into standby, it means you are running below 11 Volts. Your battery will not last long. Opus goes into standby if voltage drop exists for 10 seconds or more. No capacitor will help.
P4_2.66GHz is offline   Reply With Quote
Old 03-02-2004, 03:29 PM   #7
Cherub211's Avatar
My Photos: (0)
It will, by supplying the exta voltage for the required time of sitting at a light. What do you know about electronics?
Old 03-02-2004, 03:45 PM   #8
P4_2.66GHz's Avatar
My Photos: (0)
I know a bit about electronics.
Battery in its normal charged state should be 12.3 Volts.
Anything below is damaging.
Alternator supplies 14.1-14.5 Volts to charge the battery.
Opus power supply cuts the power off if your voltage drops below 11 volts for longer than 10 seconds.
Conclusion:
The only way you would achieve the needed result that is to run your alternator in normal mode.
Old 03-02-2004, 03:50 PM   #9
Cherub211's Avatar
My Photos: (0)
What you said there was true, but a capacitor (and I'm talking .5-1 farads) would hold the voltage high for the computer to remain on while at a red light.
Old 03-02-2004, 03:52 PM   #10
P4_2.66GHz's Avatar
My Photos: (0)
It will not hold it long enough!
BatCap would be a better solution than a reqular capacitor. Still, if he is running below 12V, his battery is taking a big hit. No capacitor can help there.
Sponsored Links
Old 03-02-2004, 03:56 PM   #11
Cherub211's Avatar
My Photos: (0)
Can we just agree that he should put the original pully back on the car?
Old 03-02-2004, 03:58 PM   #12
P4_2.66GHz's Avatar
My Photos: (0)
Yes, that would be the only plausible solution.
Old 03-02-2004, 06:14 PM   #13
My Photos: (0)
hehe.. ok you bastards i went to the dealership and bought the factory belt.... $62!!!! I'll probably throw the pulley back in tonight.
the strange thing is, i have a voltmeter on my capacitor, and it never goes below 13v w/the engine running.
I'm wondering if the opus is getting less voltage due to the fact that it's on a different circuit.
anyways.. pulley going back to stock, the thing was worthless anyways... produced like .5whp
Mods: Yep
Old 03-02-2004, 06:23 PM   #14
Registered User
Sh0cker's Avatar
My Photos: (0)
lol...you have to love those bastids on this forum
Danny.
Old 03-02-2004, 06:34 PM   #15
My Photos: (0)
of course... that's why i come here
Mods: Yep
Sponsored Links
vB code is On
Trackbacks are Off
wierd power problem (opus or m10000 prob) ob1 Power Supplies 4 03-31-2004 01:32 PM
Mp3Car.com Store carrying OPUS Power Supplies Zip-Lock Classified Archive 4 02-24-2004 10:39 AM
OPUS power supply xenonflx Newbie 1 11-30-2003 05:06 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 06:32 PM
More info on OPUS automotive ATX power supply InvisiBill Power Supplies 3 08-16-2002 02:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
