Old 03-03-2004, 07:13 AM   #1
moahdib's Avatar
moahdib
Talking Startup pulse fix with Jeff Shutdown Controller
I found a nice and relatively easy fix for those who are using laptops or atx mobos with no auto turn on feature in bios.
Just add a relay, a cap and resistor. See image below.
You get a nice 2 second pulse on the ATX wire ( connects to ground) when you first turn on the car. Then the shutdown controller takes care of everything when you turn off the car. Basically you are getting a pulse whenever the switched 12V line goes from off to on.
This is an old drawing I made of the controller years ago and I just edited a bit.
Hope helps those of you with that problem.
If you are looking to build the whole controller go to www.carpc.tk for a detailed description of all the parts.
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Advertisement Sponsored links
Old 03-03-2004, 08:28 AM   #2
Jamez_Warner
jeff's shutdown controller can be modified to add auto turn on by adding a single capacitor to the board - ask him about it...
all that effort may have been in vain
www.digital-car.co.uk - The UK CarPC Forum
Jamez_Warner is offline   Reply With Quote
Old 03-03-2004, 12:51 PM   #3
moahdib's Avatar
moahdib
No, I have talked to him. If you add a single capacitor and resistor, when you manually turn off the computer, then turning off your car will restart it again. This doesn't happen in my drawing. You only get a pulse when turning ON. The simple relay, cap and resistor can be used for other applications like auto turning on the lilliput etc... If you use a pot you can also vary the timing of the pulse.
Well thi
This certainly beats using somethign like a DEI 528T pulse timer relay. =)
I have some pics of my modified mastero shutdown controller.
Sorry for the quality, im using my palm camera.
My TL CarPC ver2
How long does Jeff Mucha thake to ship his Shutdown controller? bertybassett Power Supplies 19 02-19-2004 10:45 AM
Jeff Mucha shutdown controller, need some assitance! SLAYER6669 Power Supplies 13 02-09-2004 09:25 PM
Jeff Mucha Shutdown Controller $20 shipped magicogar Classified Archive 6 01-03-2004 12:36 PM
Complaint on Jeff Mucha's shutdown controller febsperanza Power Supplies 10 06-29-2003 01:51 PM
