it won't hurt anything. in addition one thing you might want to do is get a switch, a DPST with center off switch, and then have center be "off", one way be positive battery terminal, and the other position be accessory. then using this switch you can control what your PC does. you can force the computer to remain off (in the center position), force the computer to be on regardless of ignition switch, or operate normally.
that's what i did. mind you my experience with the ITPS/PS has not been favorable, as it doesn't provide adequate power to the 12 volt line to power my hard drive. so, if you're using any 3.5" drives you need to be aware of that.
quincy
