Notices
Old 03-09-2004, 09:16 AM   #1
Crank issue w/ reboot
Currently I have a 225 watt power inverter powering my Shuttle XPC. The PSU of the shuttle is only 200 watt so its strong enough. When the car is on, but not running and I start the car, naturally the computer will reboot from the voltage drop.
Whats the most cost effective way to remove that issue?
breimann is offline   Reply With Quote
Old 03-09-2004, 09:24 AM   #2
Raw Wave
Confused's Avatar
You've got 3 choices.
Build yourself a tank circuit.
Build yourself a power supply such as the Sproggy which survives crank (do a search)
Buy an Opus power supply.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 03-09-2004, 09:24 AM   #3
Super Moderator
hijinks21's Avatar
search the forums for tank circuit
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 03-09-2004, 09:45 AM   #4
Confusion Master
Enforcer's Avatar
Funny, at the moment (I have just received my opus) I am using an inverter and find the PC still runs through cranking, the only time it doesn't, is when I got the lights on and have used the PC with the engine off for a while.
Enforcer is offline   Reply With Quote
Opus and diesel engine crank? bridqer Power Supplies 5 03-08-2004 09:59 PM
Does your Opus 90 surive crank and perform shutdown? quinxy Power Supplies 13 03-07-2004 12:45 PM
Need to find acc wire that stays alive during crank. Bobby Digital Power Supplies 17 02-05-2004 06:42 PM
User sites issue? C4M Mp3car Forum Suggestions/Comments 2 10-23-2003 07:10 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 07:32 PM
