Old 03-14-2004, 10:14 AM   #1
Navigator_82 is on a distinguished road
ATX, ITX DC-DC Power Supply
This may seem like a dumb question but will an Opus DC-DC ATX power supply work with an ITX form factor? I am purchasing an Epia M10000 motherboard and need to know if this power supply will work with it. I also noticed that there are many different wattage variations you can purchase. I saw 60, 90, and 150. I plan on running HD, memory, USB Linksys, Internal DVD player, and possibly a USB GPS receiver. Which power supply would be best for what I need. I don't want to buy to much power because of cost...
I also need a controller with the power supply if I want the start up and shut down feature correct? Thanks for you help!
Navigator_82 is offline   Reply With Quote
Old 03-14-2004, 10:58 AM   #2
kami333
Yes, mini-ITX and ATX share the same wiring scheme. 90W should be fine, 60W is usually enough for a M10000N and a hard drive so you want a little extra to power the other stuff.
kami333 is offline   Reply With Quote
Old 03-14-2004, 11:07 AM   #3
Does the OPUS 90 watt come with a built in controller or do I need to purchase the ITPS?
Old 03-14-2004, 11:22 AM   #4
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Did you do "ANY" reading bofore posting your questions?
Yes it has a controller
TruckinMP3
Read the FAQ!
TruckinMP3 is online now   Reply With Quote
Old 03-14-2004, 11:26 AM   #5
Thanks for the reply..... Sorry for not lookin first
More info on OPUS automotive ATX power supply InvisiBill Power Supplies 3 08-16-2002 03:19 PM
what is the cheapest DC to DC ATX power supply available? Squeezer Power Supplies 9 07-29-2002 02:17 PM
What are the ATX DC to DC power supply options? Squeezer Power Supplies 6 07-08-2002 05:25 PM
DC ATX Power Supply Link xa0s General Hardware Discussion 0 08-29-2000 12:30 PM
dc to dc ATX power supply Kaizer Soze General Hardware Discussion 10 10-21-1999 08:47 PM
