Old 03-16-2004, 03:26 AM   #1
MerlinDaHapyPig is on a distinguished road
Inverter Power - Autoelectrical q
Should an inverter be run on a completely separate power wire to the audio system/amps etc. all the way back to the battery?
I asked my autoelectrician about my proposed setup and he said you have to do this. He said that around each wire is a magnetic field and if they are run off the same power wire / distribution block the magnetic field generated by the invertor will intefere with the power line to the audio amplifiers which will cause a buzzing and possibly can cause damage to the amps.
Im still not 100% sure how he explained it to me, but that was the jist of it.
In the end, i ran power down one side of the car for inverter, another power for the amplifiers down the middle and then all my speaker wires & RCA's and computer wires etc. down the other side. I have zero problems with noise, SQ is perfect.
I've heard a lot of people are having troubles with inverters and im wondering why, mine has been completely painless and the entire system works great.
Any clarification / comments / death threats are welcome! thanks guys.
MerlinDaHapyPig is offline   Reply With Quote
power inverter ruined ABS? Parsec Power Supplies 5 08-11-2003 08:08 AM
UPS power backup as inverter? CA 3000GT Power Supplies 11 02-13-2003 02:52 PM
odd inverter behavior jshrieve General Hardware Discussion 30 04-10-2001 05:53 AM
Have to switch inverter off and on to power up pc mbowler General Hardware Discussion 10 08-22-2000 12:00 AM
300 watt power inverter problems DaPyro General Hardware Discussion 6 03-10-2000 03:56 PM
