Notices
Old 03-17-2004, 06:06 PM   #1
slffl's Avatar
Using 12v plug for power to OPUS???
I have a 12v power plug in the back of my xterra. Would it be possible/safe to use the wire from this outlet to power the opus, intead of running a wire all the way to the battery? Thanks.
slffl is offline   Reply With Quote
Old 03-17-2004, 06:10 PM   #2
telekineticfool's Avatar
Yes, that should be fine. If I were you I would t-tap from behind the power point (looks cleaner) and check to see that there is a high enough fuse on it that you won't blow it. Make sure you don't blow the fuse. You will also want to find out if it is a switched power supply or not....is it on even when the car is off? You want it on an unswitched source, but need a connection to like a cigarette lighter that goes on and off when you turn the car on and off to tell it when to power up and shut down.
MP3 MR2 (click here for details)
Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
Software: Windows 2000, Media Engine 2.0
telekineticfool is offline   Reply With Quote
Old 03-18-2004, 01:17 AM   #3
make sure it has power all the time.. not just when car is on.. you'll also need to run a wire for the key sensor
beaverpants is offline   Reply With Quote
Old 03-18-2004, 02:31 AM   #4
frenchnew's Avatar
Please RTFM (Read The Fine Manual) of your Xterra for the current limit of that socket. Most of them will supply only 10 Amps on other vehicles and I do not know the specifics for your Xterra.
Also, you do not state the Opus Power Rating. If it's a 90W, you should be fine. If it's 150W you might be at the limit. Also, get yourself better socket/plug then the one provided. THose lighter plugs are not the greatest and have a nasty habit of having poor contact resulting in overheat situation.
I suggest something like a powerlink connection that are available (75 Amps Rating with 10 Ga Wire, 50 Amps Rating with 12 Ga wire) THis should cost about $10USD in the good US of A For a 2 wire connector( 4 contacts and 4 housings).
check the following link for a picture of the connector
https://www.delcity.net/tstore/servl...tid=111&page=1
frenchnew
frenchnew is offline   Reply With Quote
Wtb - Opus 150 Watt 12v archimense Classified Archive 0 03-08-2004 08:41 PM
No 12v Device+PW120a v Opus 90w zvi Power Supplies 0 02-03-2004 01:06 PM
Opus DC-DC 90W 150W Pricing Dimensions Info Linus Power Supplies 9 10-15-2003 04:29 PM
multiple items on 1 12v accessory plug... also where to find dc-dc supply Valhalla1 Power Supplies 5 07-12-2003 02:43 AM
just installed 12v Opus 150 Watts samc Power Supplies 8 05-01-2003 03:52 PM
