Notices
Old 03-19-2004, 09:48 AM   #1
Richie's Avatar
opus wont start, ign wire...?
Hi!
Sitting in my car right now on my laptop, trying to install the opus 90w in an old Opel.
Connected the - and + to battery, and opus started blinking (short blink, 2.5 sec rest, and so on.) and computer doesn't start. Haven't conneced the blue ign-wire, do i have to use it, or can i get the computer to start in another way or any tips where i should connect the ign-wire, any wire behind the radio?
/Richie
//Richie
My Nissan 200SX
Richie is offline   Reply With Quote
Old 03-19-2004, 09:50 AM   #2
samc's Avatar
connect the ignition, if your just testhing it just tap off a fuse or whatever and put a 12v to it.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 03-19-2004, 10:03 AM   #3
sfay93's Avatar
You need to find an ACC wire. This is a wire that shows 12v when the key is in the ACC position and the run position. You can find one either behind the radio or in the steering column harness.
sfay93 is offline   Reply With Quote
Old 03-19-2004, 10:18 AM   #4
for testing purposes, you can hook it to any 12V, just as samc said.
Personally, I'm never going to hook it up to ACC but to a manually switched 12V line.
wizawuza is offline   Reply With Quote
Old 03-19-2004, 10:25 AM   #5
sfay93's Avatar
Yes, you can hook it to any 12v wire but you also have to unhook it when you are done if the wire is constantly charged otherwise he would have to shutdown and startup manually everytime. My suggestion previously was in the event that he wanted it to work as advertised. Computer boots/comes out of hibernation when he starts the car and shuts down/hibernates when he turns it off. I actually plan on using a switch and relay along with the ACC wire so I can manually startup/shutdown if needed.
Old 03-19-2004, 11:25 AM   #6
Richie's Avatar
thanks guys, i connected the ign-wire to 12v and now it works fine.
/Richie
//Richie
My Nissan 200SX
opus 90 watt, wire + fuse questions studmonk3y Power Supplies 1 02-26-2004 09:55 AM
Hooking OPUS to IGN wire?!? XxAndyxX Power Supplies 5 01-21-2004 07:21 PM
What gauge wire for opus? XxAndyxX Power Supplies 6 01-20-2004 12:21 AM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 11:58 PM
Instant Start on Opus? tejesh83 Power Supplies 3 08-27-2003 07:40 PM
