Notices
Old 03-21-2004, 06:01 PM   #1
supralightning's Avatar
Grounding concern (not normal grounding issue)
I chose to remove my pwr supply from the case (pwr supply case) since its much smaller that way. Now the grounding pin for the power cable had a grounding wire connecting it to the case (power supply case). Now that i dont have this case, where should i make this grounding wire go (the case im putting the supply in is plexiglass.) Thank you
-EVOXTC
Vehicle: 2003 Mistubishi Evolution
PC Specs: 1gHz Nehemiah M10000
512mb RAM
Windows XP Professional
80gb 7200rpm 8mb cache HDD
UI: MediaEngine 2.1
supralightning is offline   Reply With Quote
Old 03-21-2004, 09:08 PM   #2
Ground it to the frame of your car, preferably to the same spot you're grounding your inverter if you're using one.
Hamster O Death is offline   Reply With Quote
Old 03-22-2004, 01:02 AM   #3
so im grounding the 3rd pin from the power connecter to the car? just want to be sure
-EVOXTC
512mb RAM
UI: MediaEngine 2.1
