Notices
Old 03-22-2004, 07:46 PM   #1
Visual Echo's Avatar
Question Can you adjust shutdown voltage on Opus 150w?
Well, the power supplies from I-Tuner I can't say much about... but they aren't working. So now I need a REAL supply.
Is the 'low battery shutdown voltage' adjustable on the Opus 150 Watt SFX DC-DC Vehicle Power Supply for ATX?
According to the stats, it's 11v +/- 0.75v
I'll be using it in a car that already has an auxiliary deep-cycle battery, it's solenoid linked to the car battery when ignition on, and stand-alone when ignition off... so I can drain this aux battery flat, and the car will still start. When the ignition is off and it has a computer load, it might only show 11.5 volts (freshly charged from AC even), this would be under shutdown voltage according to the specifications for the 150w.
I would want to adjust this to the small end... no shutdown until 10.25 volts, is this possible?
Then again, it would still run at under the low voltage shutdown level ( 7 - 10.25V) for up to an hour (if changed from factory default of 10 secs), right?
http://www.visualecho.org/carputer/guts.jpg
Visual Echo is offline   Reply With Quote
Advertisement Sponsored links
Old 03-23-2004, 04:04 PM   #2
bump
Old 03-23-2004, 04:11 PM   #3
Cherub211's Avatar
This would be best directed at Kris from Opus. I don't belive there is any way to do what you are looking to do, but Kris would certainly know more.
Cherub211 is offline   Reply With Quote
Old 03-24-2004, 08:38 PM   #4
The OPUS shutsdown at ~10.9 volts after 1 min. It would require a change in the microprocessor code to accommodate your request of changing that value. You can get that changed if you order in quantity about 100 units, otherwise it’s not something that you can change yourself.
Zip-Lock is offline   Reply With Quote
Old 03-26-2004, 09:04 AM   #5
Thank you! I was hoping I could just change a resistor or zener diode, but I will have to risk it.
Closed - Possible Opus Group Buy BoraXP Classified Archive 319 05-18-2004 11:03 AM
New OPUS 150w not working? kylechughes Power Supplies 4 01-27-2004 03:21 AM
Does the Opus 150W have an ATX12V connector? shchua Power Supplies 3 11-30-2003 09:54 AM
Opus DC-DC 90W 150W Pricing Dimensions Info Linus Power Supplies 9 10-15-2003 04:29 PM
Older OPUS 150w /w EPIA-M mod? GTC Power Supplies 0 09-19-2003 03:54 PM
