Old 03-22-2004, 10:44 PM   #1
msink
How to power the PC OUTSIDE the car?
Hello,
Wondering what the best way to power a DC-DC powered car pc is when its not in the car? Do you unhook everything, and then use a AC-DC PS inside the home? Or is their a better way to handle this, maybe with AC-DC converter?
Thanks,
Mark
msink is offline   Reply With Quote
Old 03-22-2004, 10:50 PM   #2
Ashlawn Kemling's Avatar
Ashlawn Kemling is on a distinguished road
Like you have the power blocks for laptops. Same idea.
Ashlawn Kemling is offline   Reply With Quote
Old 03-22-2004, 10:59 PM   #3
msink
Thank you,
Which type of plug does the Opus 150 and 90W PS take, and is there a favorite converter people are using inside the home?
Thanks,
Mark
Old 03-23-2004, 10:06 AM   #4
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Currently I have inverter setup in the car, but soon to be replace with sproggy DC-DC PSU. My Mastero/Sproggy 3.0 can't handle the hardrive. Once I have DC-DC PSU, I just use AC-DC PSU inside the house. It's not that complicated and only 2 connections to plug and unplug.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-23-2004, 10:25 PM   #5
cdm
cdm is on a distinguished road
well you only really need to unplug the atx connector and hard drive.. and parhaps a cd/dvd/cdr whatever drive if you have it. so a normal atx supply should be quite the best route to go
cdm is offline   Reply With Quote
Old 03-24-2004, 06:42 AM   #6
binary.h4x's Avatar
binary.h4x
If you are using an Opus, you chould just disconnect the ATX P1 connector from the Opus then put a gender changer on you AC-DC power supply, then hook up your AC-DC with gender changer to the ATX P1. That way you only need to unhook the one power plug.
binary.h4x is offline   Reply With Quote
Old 03-24-2004, 08:52 AM   #7
parawing742's Avatar
parawing742
What about an AC-to-DC converter like this: http://www.tripplite.com/products/in...ed_dcpower.cfm
Would these get the job done to run an Opus supply? How many amps does the Opus need to run?
Phillip Hullquist
I entertain people through adventure movies.
www.11visions.com
parawing742 is offline   Reply With Quote
Old 03-24-2004, 11:06 AM   #8
Cherub211's Avatar
Cherub211 is on a distinguished road
Uh, well... power = voltage x current... so 90watts / 12 volts = 7.5 amps. It's not so hard to just swap out the power supply though.
Cherub211 is offline   Reply With Quote
Old 03-24-2004, 11:38 AM   #9
[iG] is on a distinguished road
For 150W Opus:
AC to DC Supply
120V Input
12~15 Output
10~12.5 Amps
Right?
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Old 03-25-2004, 12:52 PM   #10
yellena
While my box is not in the car, I use the AC-DC power adapter that came with the case (morex cubid 2677R) which provides +12V DC:
I replaced the existing female power plug and wiring with a new plug wired to the Opus. I then added another female power plug for the remote turn-on signal. I added an SPST switch with a diode to override the remote turn-on signal. When I bring the box inside, I simply connect it to the AC-DC power adapter and flip the switch.
Code:
O +12V O head unit .----------. | | | DC-PS | | --- | | | \ / | | | --- | | | | | | | | | | | o--------------o Remote | | | | Turn-on | | \ switch | | | \ SPST | | | | | | | | | | '---------------o--------------o Vin | | | | | '----------'
yellena is offline   Reply With Quote
PC To Car Speakers eCar™ General Hardware Discussion 5 08-17-2008 01:35 PM
WTF LCD gets no power from my car pc but gets signal from home pc? Sid3ways S13 LCD/Display 6 08-22-2005 02:10 AM
Need some advice? CAR PC Short Life bklynkaos General Hardware Discussion 29 02-26-2004 05:41 PM
Experienced PC guys needs Car Audio Primer SwapMeet Newbie 6 02-10-2004 05:33 PM
About power Supply to PC in car Sk8te General Hardware Discussion 2 11-11-2000 11:39 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
