Old 03-23-2004, 01:08 AM   #1
syclone477 is on a distinguished road
Simple Idea for keeping power to inverter while cranking....
Hows everyone doing??
Great site going on here, and this is my first post. I have been doing alot of searching and read through all the people getting the dc-dc power supplies,tank circuits, hooking up ignition wire and power wires with diodes all to get their car pc to turn on. Then I thought of an idea, I havent seen this mentioned so Ill pass it by you guys and tell me what you think. I was thinking of using the power wire that feeds the ignition coil that every vehicle has. This line usually get power when the key is turned to the "on" position, and does not lose power while cranking, and keeps power while vehicle is running. You would just use this wire to trigger a relay that would then turn on you inverter, so you would be stealing very little power from the feed to the coil. This is obviously for the guys just starting a system(like myself) that want to use an inverter. I thought that was a pretty simple solution, what do you guys think??? Fern
syclone477 is offline   Reply With Quote
Old 03-23-2004, 10:03 AM   #2
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
If you are just trying out, that a way to go. Cost lots less than the DC-DC route.
Check this thread for other option to have power while the key in the ACC position as well.
http://www.mp3car.com/vbulletin/power-supplies/22203-how-keep-your-invertor-alive-while-cranking.html
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Power Problems Please Look kmfdmk General Hardware Discussion 15 02-15-2004 09:39 PM
how many power wires to run into the trunk for inverter and amps? djrkd Power Supplies 13 11-15-2003 03:18 PM
power supply idea, will it work? ares Power Supplies 2 03-10-2003 09:27 PM
Idea about how to power in the house Rob Withey Power Supplies 12 03-30-2002 02:42 PM
Simple idea, simple question.... cruzc_99 Power Supplies 1 09-17-2001 02:35 AM
