Quote: Originally Posted by DSM97RS
i have the opus 90w hooked up the the m10000. Off the actual opus board on one side is the power ground and accessory wire, and on the other side is the power connector running to the actual motherboard. My question is, my power switch on the case is plugged into the motherboard and there is an empty connector on the opus that has the power swith label on it. should the power switch from the case be plugged into the motherboard or the case?
You dont want to use the switch on the case at all. You want the Opus to do the switching for you (auto on and auto off), so you connect the Opus to the power switch connector on the motherboard. I believe on mine it was a little green and white pair of wires with the little connectors on them.
