Old 04-03-2004, 01:29 PM   #1
Pingo1969 is on a distinguished road
power on problem ??? help please anyone
hey...
i have installed my system and i works great when i can get it to turn om ..... problem is that only every 5-10 time i power the computer up, that i actually boot up....i dont know why ???
some times it power instantly, and some times the screen just reads "NO SIGNAL" and nothing happens but my computer is starting that i can se and hear....does anyone know of this problem ???
is it the controller on the motherboard that is the problem ? i have changes the harddrive to a brand new 80 GB and it works great, so that isent the problem....
Best regards
Kenneth
Pingo1969 is offline   Reply With Quote
Old 04-03-2004, 01:49 PM   #2
Raw Wave
Ricky327
Hmm...can be anything really. Most likely its the motherboard.
Go for minimal cofigurations, remove the hdd, cd, extra ram or card.
If you can boot up ok with bare PC then you know the problem is on one of the part you taken out. Put them back one by one until the problem reoccur.
Hope that helps anyway.
Ricky327 is offline   Reply With Quote
Old 04-03-2004, 01:52 PM   #3
Nav_Attack is on a distinguished road
what Ricky told you is good advice.. but if you can really hear your system booting, what does that mean exactly? you can hear the harddrive/cdrom drive start spinning? that may not mean that the computer is starting, just that your drives have power.
so like Ricky said i'd try booting with just the mobo and video card.. it should fail on bootup with a no ram message, but you should see that. then add ram. try again. then add hdd. try again, etc.. it could also potentially be your video card.
i know its not very helpful at this point, cause it really could be anything.
VIA EPIA 533 MHz
256 MB RAM
7" Lilliput VGA Touchscreen
20 gig HD
Media Engine 2.1.4
GPS - Earthmate/SA2004
802.11b Connectivity
Nav_Attack is offline   Reply With Quote
Old 04-03-2004, 01:55 PM   #4
Raw Wave
Ricky327
Yeah...the sound doesnt mean much but atleast the power is getting through...or some of the power
Old 04-03-2004, 02:00 PM   #5
it all sounds right but when i boot up in 220 V there dosent seems too be any problems it`s only when i boot up in tha car ????
Best regards
Kenneth
Old 04-03-2004, 02:48 PM   #6
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
That suggests that your power supply is at fault. What is your power solution?
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 04-03-2004, 03:48 PM   #7
it is a ITPS Low dropout and power sequencer module, and a 12 power suply
Kenneth
Old 04-03-2004, 04:15 PM   #8
Raw Wave
Rob Withey's Avatar
Kenneth
Are you starting the computer with the engine off? ITPS drops the voltage by about 1.3V and the 12v power supplies (if it's a pw series unit) generally won't boost it back up for the 12v line (they have no regulation on the 12v line). Check the 12v power coming out of the power supply for a low voltage.
Old 04-03-2004, 04:23 PM   #9
i usually first start the car, before i start the computer by switch on the dashboard, ...
does any of u know if it is a problem if the harddrive and the computer is tiltet and not possitioned vertical og horizontal ???? could it be the problem ? i have boltet the computer to the backside of the rearseat,??
Kenneth
Old 04-03-2004, 04:26 PM   #10
when the car is running and the computer i measured the power supply on the amp, ( i have 2 amps installed, connected to the same powerwire as the computer..) it measurer 13.9 volts when the car is running, and 12 volt when the computer is on and the car engine stopped...
Kenneth
Old 04-04-2004, 05:20 AM   #11
Raw Wave
Rob Withey's Avatar
Kenneth
So you didn't check the 12v coming _out_ of the power supply like I suggested. <shrug>
Old 04-04-2004, 09:36 AM   #12
Raw Wave
Ricky327
Hes getting 13.9V in the the ITPS. That should be enough to put out a constant 12V.
Yes as rob said do measure the in and out voltages of the ITPS. If you do get a 12V out of the ITPS then it should work fine.
If you are still having problems I suspect the ITPS is having problems turning your PC on. Verify this by connecting a spare PC on/off button directly to the motherboard. See if you can turn on your PC on/off manually with the ITPS supplying the power.
Old 04-04-2004, 09:48 AM   #13
Chris732 is on a distinguished road
hey...
Best regards
Kenneth
I had the exact same problem with my lilliput. It turned out I had a bend in the monitor connector.. Recheck it to make sure all the pins are perfectly stright.
Chris732 is offline   Reply With Quote
Old 04-04-2004, 10:31 PM   #14
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
It could be because you screwed with some settings in the bios. I just did that yesterday. I set a setting in the Advanced Chipset features to LCD by acciden and was left with no screen. I had to flash the CMOS.
antimatter is offline   Reply With Quote
Old 04-05-2004, 03:36 AM   #15
okay i will have a look in the BIOS, .....
but could it really be the problem, cause sometimes it works fine and starts like it should ???
i just tried to put a new RAM block in and then it startet the first time, so maybe its was a bad ram block i had in ???
i will now wait till morning to see if it wil start then, cause the carputer has never been able to start after it has been left in the car overnigt....so if it starts i the morning, the problem may be solved....i hope
thanks for all your replys, can only say this i truly a great forum !!!
Best Regards
Kenneth
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
Power Problems Please Look kmfdmk General Hardware Discussion 15 02-15-2004 09:39 PM
Epia vs. Regular Motherboard jnusaira Newbie 14 02-09-2004 09:49 PM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 06:27 PM
Average power breakdowns Telek Power Supplies 0 11-23-2001 08:07 AM
