Notices
Old 04-04-2004, 02:57 PM   #1
OPUS 150 with athlon 1ghz?
Hey everyone...I know im new and I've hung out on forums before so I searched for all the info first.
Anyway, I used http://www.mymp3car.com/mp3car/PSUpower.asp wattage calculator and I'm at about 128 watts of power consumption (112 without a DVD rom). Another site I found put me at 238, but adding the numbers myself tell me that I need 168 watts of power.
I plan to run the following setup
Iwill KA266
Athlon T-Bird 1GHz
256 DDR Ram
Geforce 2 MX 32MB
SB live 5.1
7200 3.5" HD
7 fans and some usb devices...
I'm a little skeptical as to whether or not the OPUS 150 will run all this, but I also know that the wattage calculator output the maximum draw of each part. I think I'll be ok, but could anyone verify this for me? Thanks a lot!
aznblueeboi is offline   Reply With Quote
Old 04-05-2004, 12:31 AM   #2
Iwill KA266
Athlon T-Bird 1GHz
256 DDR Ram
Geforce 2 MX 32MB
SB live 5.1
7200 3.5" HD
-7 fans may be a bit of an overkill.
-For usb you can always go with a powered hub, so you won't be draining the computer.
-If you are planning to buy these parts and are not reusing the old ones, switch for Atholon XP-M, they draw less. Also you will reduce power consumption by much if you switch to laptop hdd.
arkadiyp is offline   Reply With Quote
Old 04-05-2004, 01:17 AM   #3
im just running 3 input and 3 output and one fan on the core...
i do plan to run a usb hub
i know that the mobiles draw less but the chip was free so i think im going to crank down the volts in bios...
but will the opus run it? im gonna try an inverter setup first...
thanks!
Old 04-05-2004, 02:12 AM   #4
Banderon's Avatar
I'd never seen that calculator thing before. It never even occured to me to search for one. What a good idea!
Banderon is offline   Reply With Quote
OPUS 150 three flashes spyda Power Supplies 3 03-22-2004 09:27 AM
WTB: Opus 150 PS... need ASAP hyperspeed Classified Archive 4 03-11-2004 06:11 AM
Can the OPUS 150 W support this setup? kiztope Power Supplies 1 01-14-2004 11:45 AM
OPUS 150 watt, USB stays powered??? GScherler Power Supplies 1 12-19-2003 03:44 PM
WTB: Opus 150 (Or trade for my 250W Keypower) SuperMatty Classified Archive 3 06-27-2003 02:56 PM
