Notices
Old 04-08-2004, 10:34 PM   #16
S4Per's Avatar
I'm starting to think about this, tell me if it makes sense:
The front USB ports are NOT integrated into the mobo, therfore they have an actual connector that plugs into the mobo. What if a relay of sorts was wired into the particular power line here on the connector, which would be triggered to turn the power off based on the PC being shut down?
S4Per is offline   Reply With Quote
Old 04-08-2004, 10:40 PM   #17
FLA
gospeed.racer's Avatar
Suppose it would work, but I dont think powering a relay off a usb port will be that good. I prefer the fan connector because it is made for higher current draws.
I think I may be misunderstanding you though. Are you trying to turn off the usb's or cut power to the whole system?
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 04-08-2004, 10:44 PM   #18
Personally I want to cut main power to the Opus after it has triggered the shutdown of the system so that the USB ports dont have power. I also want it to reset quicky so when i turn the car to ACC or further the computer comes on without having to push any buttons other than turning the key.
2003 Subaru Impreza TS
Staus: Done.. too lazy to make pictures lol.
Maeveth is offline   Reply With Quote
Old 04-08-2004, 10:55 PM   #19
I agree. That's what I have in my setup - a shutdown controller that cuts power off to the Opus 30 seconds after ACC goes off. Otherwise, my USB devices (Lilliput touchscreen controller and USB GPS) draw enough power to drain the battery after a couple of days.
shchua is offline   Reply With Quote
Old 04-08-2004, 11:01 PM   #20
Raw Wave
gospeed.racer,
The problem with using the fan connector is that the motherboard must turn the fan on all the time as long as the PC is on...noisy to some poeple and some BIOS may not support "fan on" at all time. There are some "sensitive" relays these can be swithed on with minimal current if you need to use one.
Such as :
http://www.maplin.co.uk/products/mod...599&Products=2
Ricky327 is offline   Reply With Quote
Old 04-08-2004, 11:08 PM   #21
Raw Wave
PS...
It is also possible to get the power to turn on the relay directly from the FDD/HDD power connector, a +5V or 12V is always available there. Just buy one of those extension/splitter cable and wire a standard 12V relay from there.
Old 04-08-2004, 11:26 PM   #22
FLA
DOH!
Why is it that the most simple things always slip right past me! Yes, using the molex would be a much better idea, thanks!
Old 04-08-2004, 11:32 PM   #23
Raw Wave
I was actually just about to post...why not tap into the PC power connector. But then oh yeah the FDD/HDD power connector will work and the cable are so easy to find too
I think its bed time for me.
Old 04-09-2004, 12:25 AM   #24
Raw Wave
Heres a circuit that may work with your problems :
This circuit assume the OPUS will work fine if the +12V and the IGN wire come on at the same time. Otherwise a delay may be needed before the IGN go to +12V.
Heres a run down of how it work. The IGN line from the car put a supply to the OPUS with a +12V, this 12V also triger the OPUS to turn the PC on.
Once the PC is on, the relay powered by the 12V supply of the HDD connector closes the relay switch, supplying the permanent +12V into the OPUS +12V (nothing happen here)
When the IGN is lost (theres still a +12V supply to the OPUS from the relay switch), the OPUS then send a signal to the PC to turn off. The PC then switch off and turning the relay off. The power into the OPUS is now completely cut off.
Hope its clear...as I said I dont have an OPUS and cant test it. Someone who know enough may wanna try...please do so, just dont blame me when something smoke up :P
It may not work as I mentioned earlier as some assumption are made.
Old 04-09-2004, 12:29 AM   #25
Raw Wave
Im even assuming thats what the OPUS connection look like...
Those with OPUS may wanna comment
Old 04-09-2004, 12:39 AM   #26
Raw Wave
S4Per,
Yes you can do this...
On my post #21. Buy a HDD cable splitter, connect the relay coil and a diode on the HDD cable 0V and +12V. The relay switch can now be used to cut off the USB supply between the motherboard and the USB port on the front.
I havent tried it as I have no need but it should work.
Hope that helps
Old 04-09-2004, 12:48 AM   #27
S4Per's Avatar
Thanks everyone. You guys rock! I think I'm going to try this last one first, and if it doesn't work, I have a lot of other things to try.
Thanks a ton!
Old 04-09-2004, 12:50 AM   #28
Raw Wave
Good luck...
No matter what you do dont forget the diode in parallel with the relay coil. 1N4001, 1N4002 etc should work ok.
Old 04-09-2004, 01:15 AM   #29
It seems that most motherboards power the USB ports off the +5VSB. How about replacing the +5VSB pin on the ATX power connector with +5V ? This will ensure that power to USB ports is cut when the PC is off. I'm not sure if the motherboard will power on without +5VSB but its worth a try.
Old 04-09-2004, 04:00 AM   #30
Raw Wave
Laidback's Avatar
Quote: Originally Posted by Ricky327
Good luck...
What's the diode for?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 19 05-20-2008 09:05 AM
Lilliput USB driver CPU usage question. AustnJPR LCD/Display 0 04-06-2004 02:59 PM
FS: 4-port powered USB 2.0 Hub $10 Shipped Altimat Classified Archive 5 02-14-2004 04:30 PM
Creative Labs may have the MP3 car solution... GinoRP Input Devices 1 12-21-2003 03:24 PM
USB Sound and Bus powered hub Suprapc General Hardware Discussion 10 04-21-2003 04:21 PM
