Notices
Old 08-21-2004, 08:33 PM   #76
archimense's Avatar
Quote: Originally Posted by RogerWilco
haha lol its had plenty of rest! for the last 8 hours almost ! i went to a family reunion, about an hour from my house. Anyways, i was unaware (seeing as ive never used one) that the molex connector was unregulated, i was under the impression that it was. Alright looks like i'll stray from ever using one in the near future. My bad there i misunderstood how you had run the relay, did you use a ATX12v extenison cable, and not directly cut the one from the psu ?
Thanks!
The OPUS has an external ATX cable that you plug into it and the motherboard; I will be modding that one.
The molex power cable is regulated, but not as much as the USB power supply.
Jetta Install Photos
Audi S4 Worklog
01' Audi S4 Twin Turbo / 00' VW Jetta VR6.
archimense is offline   Reply With Quote
Old 08-21-2004, 08:36 PM   #77
RogerWilco's Avatar
oooh i forgot about that! my bad i have'nt actualy seen an OPUS power supply before, mines due this wensday. Very cool so i guess that would still keep the warranty. I'll have to look into this if i decide to use my full size optical dvd reader. Oh just thought of this, does the Opus 150w psu come OEM? or does it include the atx12v cable, and the HD connectors? (i bought it from mp3car.com)
'gee i hope everything came out with me'
RogerWilco is offline   Reply With Quote
Old 08-21-2004, 09:12 PM   #78
Raw Wave
rando's Avatar
Quote: Originally Posted by archimense
So am I correct in saying that the only modification you did was:
Put a DPST relay on PSON and PSBY so that they were only connected when the ACC line was high or the computer was on(HDD power)?
Yes, that's correct. Here's a schematic.
2004 4runner
rando is offline   Reply With Quote
Old 08-21-2004, 09:31 PM   #79
RogerWilco's Avatar
will have to save that schematic,
ps you should post this in the sticky'd schematics thread
Old 08-22-2004, 12:20 AM   #80
archimense's Avatar
Thanks for taking the time to post the schematic.
Audi S4 Worklog
Old 08-22-2004, 12:29 AM   #81
Raw Wave
rando's Avatar
I just updated the schematic. The previous one had a slight typo and wont work.
2004 4runner
Old 08-22-2004, 01:20 PM   #82
savante's Avatar
Not to jack this thread, or sidetrack it... but if you didn't want to go the relay route and had a self powered usb hub:
Based on the pinouts found at this page http://www.taltech.com/support/pins2.html
Could you clip the pin 1 on your hubs, Type B port as shown in the picture (I know its very blurry but take my word for it, its the right pin).
My thinking is that if its not taking the +5v from the USB bus it has to take it from the Power Plug... this way I dont have to mod the motherbooard-to-usb connection, the opus power supply or the usb cable and I dont have to use relays. All I will have to do is take 5V from the molex to a barrel plug and put it into the DC power of the hub.
Would this work? Or would the usb hub not even work without that pin connected?
savante is offline   Reply With Quote
Old 08-22-2004, 02:49 PM   #83
Raw Wave
rando's Avatar
Yes, you can power your hub(s) from your PSU output connectors and yes you can disable the 5v rail of your USB bus -- in any way you want.
It wont solve the battery drain problem though it might make it a bit better. Click the link in my sig and take a look at the current readings I measured in message #18. The m10k itself will cause the Opus to pull ~86mA from your battery -- even with ZERO peripherals attached. You need to cut the 5VSB going into the computer OR the 12V battery input going into your Opus to stop this (assuming a BIOS patch cannot help). If you cut the 5VSB, the Opus current draw goes down to a more tolerable 7mA while off.
If the relay is a big deal, you can always build a solid state version.
2004 4runner
Old 08-22-2004, 03:18 PM   #84
savante's Avatar
Thanks for the reply rando.
I hope I am not about to ask a stupid question... (its been a while since I worked with relays) In your schematic, the state the switches are in, is that the state they are in when the relay is energized, or is that a 'normally closed' state.
Again if I missed something, I apologize.
Old 08-22-2004, 03:21 PM   #85
Raw Wave
rando's Avatar
Good catch! As shown, that would be the state when the relay is energized. You want to hook things up to the normally open side of the relay. I'll update the diagram shortly.
2004 4runner
Old 08-22-2004, 03:38 PM   #86
savante's Avatar
And just for clarification, someone asked if it was a DPST relay.... but from my understanding you could use either a DPST or a DPDT with an 'open' circuited NC connection....
Is this correct applying to your schematic?
Old 08-22-2004, 04:40 PM   #87
archimense's Avatar
Correct me if I'm wrong Rando.
But you can use a DPST or a DPDT without the normally open circuit connected.
The schematic that Rando posted currently shows DPDT relays without the normally open circuit connected.
Audi S4 Worklog
Old 08-22-2004, 04:46 PM   #88
savante's Avatar
Thanks, I thought you could use either or... but I think you have it backwards.
The contacts used would be the normally open contacts which only close when the coil is energized... the normally closed contacts would be left 'open'
Old 08-22-2004, 04:57 PM   #89
Raw Wave
rando's Avatar
The schematic now shows normally open connections and a DPST relay (as I originally described). If you use a DPDT relay, then you'd wouldn't use the NC connections.
2004 4runner
Old 08-22-2004, 05:07 PM   #90
savante's Avatar
Thanks for the clarification rando, the schematic looks great. I will definitely be using it for my reference.
Best mountable, DC powered USB Hubs? Dan Marsh General Hardware Discussion 19 05-20-2008 09:05 AM
Lilliput USB driver CPU usage question. AustnJPR LCD/Display 0 04-06-2004 02:59 PM
FS: 4-port powered USB 2.0 Hub $10 Shipped Altimat Classified Archive 5 02-14-2004 04:30 PM
Creative Labs may have the MP3 car solution... GinoRP Input Devices 1 12-21-2003 03:24 PM
USB Sound and Bus powered hub Suprapc General Hardware Discussion 10 04-21-2003 04:21 PM
