Very nice theory but impossible to implement as you need the following conditions to implement a voltage divider network.
1> A constant regulated voltage source.
2> A constant current draw
While voltage divider network are easy to implement for some simple circuit like a LED light and the dissipation is very low, when it comes to power a computer it is inefficient as the voltage dropped needs to be dissipated as heat.
Take the example of the LED light (Operating Voltage of typical LED 2 Volts at 0.020Amps). If you want to operate it from 12 volts you need to drop 10 Volts at 0.020 Amps so the formula for resitance is R = V/A or 500 Ohms.
The power dissipated by the resitor will be P = V X A or 0.2 Watts.
While the whole circuit would need 0.24 Watts to power a led that consumes 0.04 Watt. This means that you will consume 5 times more power that what is needed to operate the LED, the rest is wasted as heat.
Now lets assume that you need 5 Volts @ 5 Amps from the 12 Volts,
The resitor will need to drop 7 volts at 5 Amps = 1.4 Ohms but the power dissipated by the resistor would be 35 Watts.
With the same calculations, you would use 60 Watts of power on 12 Volts to supply 25 Watts on 5 Volts (5 Volts X 5 Amps). The rest would be wasted as heat in the resistor.
Also, please note that for safety consideration and reliable operation of the resistor you would need to double it's power rating. For your 5 volts circuit at 4 Amps, that 1.4 Ohm resistor would have to be 70 Watts minimum.
Theses factors are the reasons behind switching power supplies which are more efficient then a simple resistor divider. On average most switching supplies have efficiencies of 70% and more.
Best regards
frenchnew
Quote: Originally Posted by masch
Hola
Recently someone looked at my setup and asked me why didnt I just use a voltage divider to get the +12, +5, +3.3 etc.
I figured, maybe it could work? The +5 could be tapped from a voltage divider circuit from the +12, and so could the +3.3. The only trick is to regulate the +12 no?
Or is it much more complicated that this?
