Notices
Old 04-14-2004, 10:44 AM   #1
UPS + Inverter = no go?
I install a UPS between the Inverter and CPU.
One thing I noticed the UPS said is that it's only receiving 88 volt of power and the norm should be 120.
This cause a big problem as the lowest setting the UPS can set to is 87 volt before going to battery. The UPS would constantly go on battery over a few minutes before it kicks in as AC.
Is this normal for a 300 Watt inverter to just pump out 88 volt of juice? I thought it should be 120. Anyway...I guess I'll go with an Opus as this doesn't look too good of a setup.
Is an Opus 150 enough to power up the following?
Epia M1000 (VIA)
Full Size Slot Loading DVD (Pioneer)
Full Size HD 40 GB (WD)
USB GPS Mouse (Destinator2)
Serial Touch Screen (Xenarc)
Playstation2 Joypad/Keyboard USB (Sammy)
If so...I guess I'll just get a Opus and get it over with.
nl4jy is offline   Reply With Quote
Old 04-14-2004, 10:56 AM   #2
riddle14's Avatar
i was going to do the same thing as well. the problem with this is an inverter only puts out a square wave as opposed to a true sine wave. the ups needs a clean sine wave of at least 100 vac in order to run properly. you are better off with the opus any way really cause its alot smaller and it can fit in a case as opposed to being external.
as far as having enough power for what you mentioned you should be fine.
"I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
By "ToneRiddle"
riddle14 is offline   Reply With Quote
Old 04-14-2004, 10:58 AM   #3
Yeah I guess so...But is the 150 enough for my setup?
Old 04-14-2004, 10:59 AM   #4
riddle14's Avatar
forgot to put that in there, but yes you should.
By "ToneRiddle"
Old 04-14-2004, 11:16 AM   #5
Dang...this is some quick reply...Okay...Guess I'll recycle the UPS to home use then...Thanks.
Old 04-15-2004, 08:05 PM   #6
What UPS do people use when they "tank" to keep the computer on during crank?
el bob is offline   Reply With Quote
Found someting interesting on E-Bay!!! outragis Classified Archive 929 01-23-2006 09:38 AM
Will a UPS kill my inverter? arsalan_altaf Power Supplies 6 02-14-2004 08:00 PM
Powering UPS from inverter. alik Power Supplies 8 12-13-2003 12:06 AM
UPS as an inverter? wylie-c Power Supplies 4 10-15-2003 09:32 AM
UPS power backup as inverter? CA 3000GT Power Supplies 11 02-13-2003 02:52 PM
