Notices
Old 08-31-2004, 10:31 AM   #241
Quote: Originally Posted by Xavyer
Nice Tell if it is a sollution.
But take care with the pinout
could u look at the datasheet and give it 2nd opinion, maybe i overlooked something
Maddog_rvo is offline   Reply With Quote
Old 08-31-2004, 11:19 AM   #242
MySQL Error
MatrixPC's Avatar
If you guys are struggling to get the 4.0 to work and changing from National chips to Max chips, why not go with the 4.5 design?
It's very much the same with the addition of 1 more 3.3 and 12V sections.
I have the custom 4.0 design, if you guys want, I send the PDF so you can edge your own PCB.
What does it has?
1 section of 3.3V (Max chip) base on 3.0 design.
2 sections of 5.0V (Max chip) base on 3.0 design
2 section of +12V (National chip) base on 4.0 design (similar to 4.5 design and I only use one section because the main relay can't support the current draw)
Negative voltage (-5, -12) are base on 4.0 design.
On board SDC, Low voltage shutdown, and temperature control fan base on msCar fan control circuit.
The design is powering my A7N8X-VM/400 mobo with Athlon XP2500 Mobile (running at 1.7GHz), Maddog 16X DVD ROM, 120G 7200RPM Seagate HD, Lilli LCD, and several USB devices (mouse, KB, GPS, WiFi, Card Reader, ...)
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-31-2004, 11:57 AM   #243
Xavyer's Avatar
We actually paid mastero €140,- For a full kit, I'd rather have the national version working..
About etching a PCB.. I dont have the equipment and I dont have someone who can manufacture one for me..
For the pinout of the MAX 787 You really have to considder changing the PCB
Look at the example I've made in photoshop
Xavyer is offline   Reply With Quote
Old 08-31-2004, 01:39 PM   #244
I just tested my mk4
And i'm sad to say that i have the same problem
here are my readings:
Engine off, motherboard not connected:
3.3v is 3.311v
5v is 5.00v
12v is 11.89v
12v mobo is 12.41v
-5v is -4.97v
-12v is -12.37v
Engine on, motherboard not connected:
3.3v is 3.31v
5v is 5.00v
12v is 11.89v
12v mobo is 11.74v (drop of 0.94v)
-5v is -5.03v
-12v is -13.72v (1.35v up)
Engine on, motherboard connected (and running):
3.3v is 3.15v
5v is 3.258v
12v is 11.95v
12v mobo is 11.68v
All fans are turning but the HD doesn't seem to start
(J3 was short)
My setup:
Via epia M10000
20gb 3.5" hd
256mb ram
lilliput screen (connect @ psu)
Everything works fine when the engine is not running
Hope this helps a bit to fix the problem
Soul is offline   Reply With Quote
Old 08-31-2004, 02:11 PM   #245
yup changing is absolutely a must, already changing it with a dremel
first try will be tonight i think, hope it works
Old 08-31-2004, 02:19 PM   #246
Xavyer's Avatar
This is beginning to look like a bad batch of national chips..
Old 08-31-2004, 02:28 PM   #247
indeed, i hope its just that, don't want to change the pcb for the maxim chips and the PSU works fine for others with national chips
we (me, xayver and maddog) bought the psu together so it could be it.
Old 08-31-2004, 03:07 PM   #248
Hmm yup, 2 bad i cant order samples for national chips
thats why i`m changing the pcb 2 maxim chips and see if it works, i already have a few of those (only doin it for 5V line)
Old 08-31-2004, 03:16 PM   #249
Xavyer's Avatar
Anyone heard from Gyro (the 4th guy) if he had the same probs
Old 08-31-2004, 04:51 PM   #250
I would like to report a perfect working MK4 with max787 chip and no boost line
(with boostline i got a stable 6V so i disconnected it)
5V stays stable at around 4.93V (full load of pc and a input of 11V)
will post incar result tomorrow after i bought some resistors to get the boostline correct (had 2K and i need 2.7K)
note : do not use my schematic, it is faulty use the one of xavyer instead (mine is in mirror, only works if u put the chip under the pcb
Old 08-31-2004, 06:00 PM   #251
DOes everyone's LM741 run really hot?
slboytoy is offline   Reply With Quote
Old 08-31-2004, 06:03 PM   #252
Xavyer's Avatar
Mine does, but wont burn my fingers (I have to mention that they are fairly heat resistant burning them with my soldering iron )
Old 08-31-2004, 06:08 PM   #253
whoohoo it even runs an AMDXP 2800+ proc and a P4 3.2GHz :P with radeon9500
Old 08-31-2004, 06:11 PM   #254
Xavyer's Avatar
Piczzz
Old 09-01-2004, 02:30 AM   #255
Piczzz
Will post em in about 10hours
(and dont look at the junk i made of it was testing first)
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
Opus ATX and ITX PSU - Difference? phoTToniq Power Supplies 5 09-22-2003 04:21 AM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
AT / FULL ATX PSU FOR SALE Mastero Classified Archive 2 01-09-2002 01:54 PM
AT / FULL ATX PSU FOR SALE Mastero Classified Archive 1 11-24-2001 02:46 AM
