06-05-2004, 01:43 AM
#121
Registered User
toy i have pulled it down ....
shall up load it soon
Mastero
06-10-2004, 10:45 PM
#122
No problem, I'll keep on checking back to see if they are up yet. I want to get my Epia M working. Thanks for all your work.
06-11-2004, 11:11 AM
#123
Registered User
MK-4 COMPONENT
MK-4 PCB LAYOUT
MK-4 PARTLIST
Enjoy guys ..
Full assembly details with pictures comming soon on the web.
Cheers
Mastero
06-13-2004, 05:22 AM
#124
@Mastero Can you tell me if this design comes in a "complete" kit?
It seems I just can't get the right parts over here in Holland to build your design.
It has to be ordered and the prices are very high of the parts.
06-13-2004, 11:28 AM
#125
Registered User
xavyer the MK-4partlist has few things in RED that is not there in the kit. rest everything is included.
For the chips you can try www.national.com
Email me for more help.
Cheers
Mastero
06-14-2004, 02:22 PM
#126
Rub One Out
Maestrowill the PCB fit in a micro ATX PSU?
CarPC status: iPod, 3,456,217 songs so **** you
06-15-2004, 10:13 AM
#127
is the lm2678sd-3.3 also ok
is the lm2678sd-5 also ok
Show me a hero and i write a tragedy
06-15-2004, 11:12 AM
#128
MySQL Error
The PCB was design for TO-220 type. You should get LM2678T instead
LM2678SD has 14 pins vs 7 pins on LM2678T.
The answer is NO.
06-15-2004, 12:44 PM
#129
Registered User
Mk-4 is 145mm x 110mm
You will have to check it yourself ...
Cheers
Mastero
06-15-2004, 03:48 PM
#130
Registered User
Finally found my camera USB cable
Here is how my final Mk-4 looks like, see how the heat sink is made.. More photos shall be up on the site soon
Mastero
06-16-2004, 11:37 AM
#131
Mastero,
Have you found some time to check spikes on your LM2678 output ?
I'm pretty sure your mobo won't last a long time with a LM2678 standard design.
Regards
06-16-2004, 01:25 PM
#132
Registered User
Quote: Originally Posted by eden
Mastero,
Regards
I have not actually check it! but have been running a PIII 1ghz for over a month with no problem.. shall check for spikes soon, i dont think its much.
Mastero
06-17-2004, 12:04 PM
#133
Registered User
Check out the pictures of the new MK-4 PSU www.mastero.tk
Cheers
Mastero
06-19-2004, 12:28 AM
#134
I'm about to build the MK4 (I have a Epia, so i'll tell you if it works) but.....
Initial wait = 1M pot
Cut Power time = 500K pot
200K pot? what is that for?
06-19-2004, 07:20 AM
#135
Registered User
Boytoy .. 200k pot is for generating the ATX pulse. You can set how long you want that pluse to be.
Mastero
| Thread Tools |
| Display Modes |
Linear Mode
