30 watt seems quite high. The power supply can output a peak of 18W and 2 A at 12 V + and 22.5 W and 8A at 5 V +. On the 5 V side the suppled power seems fine. I know those drives consume both 12 and 5 V at the same time. I dont know how much the board consume 12 V power but 18W doesnt seem much. Does anyone know how much 12 V power a 3.5" hdd drive and an epia mobo consumes?
edit: I just looked at couple spec sheets for a couple 5400 rpm disks and they use arout 1.9 A of 12V power and ,9 A of 5 V power. Since the board can only handle 2 Amps of 12V power, would it be safe to use it to power this drive? I just cant find how much 12 V powr epia board use. I read a couple post over the internet that they had tu put a resistor on the 12 V line of the psu for the minimum power use to be exceded. It seems that the epia boards don't even use 120mA of 12 V power (if they use any). Do the epia boards even use 12V power? if not, I would be safe.
