Quote: Originally Posted by alvins
Can this be done? I have an ITPS + PW70a and have disabled ITPS regulation because it is useless in car environment. Can I use the Lilliput egg to power both the LCD monitor and 3.5" HDD?
alvin
If the voltage to your computer drops below 12V when you crank, then so will the voltage to your cigarette lighter. Everything in your car gets its power from the same place.
But if you look at the description of the ITPS that mp3car sells, item #2 should cover your problem. Your computer won't be on while cranking... if you want your computer to be on before you start your car and survive cranking, then you will also need a tank circuit.
"The ITPS performs several timing routines and takes actions as follows:
1) Ignition=OFF. Nothing happens.
2) Ignition=ON. ITPS waits for 3-4 seconds then turns on the main 12V rail. This provides enough time for battery levels to reach a stable output. After another 1 second the MCU sends an "ON" signal to the motherboard via the 2 wires connected to the motherboard's ON/OFF pins. The motherboard will turn ON and your system should start booting.
3) Ignition=ON during driving: Nothing happens. Your computer will remain ON.
4) Ignition=OFF. IPTS waits for about 5 seconds and then it turns the motherboard OFF by sending a signal to the motherboard's ON/OFF switch. Your computer should turn off gracefully (shutdown procedure). During this time, power will still be available for your PC to perform shutdown.
5) Ignition=OFF after 5 seconds. Power will still be provided for another 45 seconds, long enough for most soft shutdown processes. In the event where the shutdown process is hanging, power will be shut down hard, turning off your computer's main power source to prevent battery drain.
6) ITPS will go to step 1, until ignition is tuned ON again."
