Yup, had this problem early on with standby, came down one morning to a battery that was around 4.5 volts after recenty setting the PC to do Standby instead of Hibernate. I discovered that the Opus low voltage shutdown was not working. Called Kris, went over the situation, he called me back a week later and told me he found the bug in the code and that I should send my unit back for re-programming. This was a few months back.
The problem only occurs when the user tells the computer to shutdown or standby. If you leave the computer alone, the Opus will shut the PC down fine after the set timeout. I disabled standby after that so I don't know what happens when the PC is set to standby.
Call Kris.
Quote: Originally Posted by Chairboy
I came down to my car last night to find that the battery was too low to start my car. It's an Opus 90, and the motherboard is an Epia M10000.
The Opus has been starting the computer fine, but I notice that it hasn't been putting it into standby succesfully. I'd come back to find the computer off and the Opus flashing 4x (which, according to the manual, means that there was an ACPI failure).
Has anyone seen this before?
