Here it is..... I'm a Mechanical Engineer.. not Electrical... so I just stole
this from the typical applications sheet of the IC
The circuit is super stable... only downside is it creates a fair amount of
heat. I used 5 amp heatsinks on the IC's but still too hot to touch.
So I used thermal paste and bolted to an alum radioshack box also.
Still hot... but u can touch it. Just have to have them mounted with space
around them.
I got all the parts from
Jameco
LM350T - IC (used in place of LM150) p/n: 23940
Heat Sink - p/n: 164734
Diode - p/n: 76961
240 Ohm Resistor - p/n: 30568
.1uF Cap - p/n: 33486
10uF Cap - p/n: 10882
1uF Cap - p/n: 154860
5k potentiometer - p/n: 95450
You use the pot to set the output voltage... I found that for 5.15 volts I
needed 750 Ohm resistor p/n: 31561, but I'd recommend getting the pot
also to test for your needs.
Total Price: $10.93 (but most parts are qty 10... except IC.. 1.75 each.. so
add 1.75 for every one after the initial money up to 10 ps)
My final results:
The second one I did was alot prettier... since I worked out all the bugs on
mounting the circuit inside the case. But I have no internal pics of 2nd one!
And these pics are before the mounds of hot-glue to support the board
Hope that helps some!
Squid
