Quote: Originally Posted by gork
What power lines are you running from the front? You should run a new circuit for the OPUS psu directly from the battery. This is especially easy since it's in the trunk already. You only want to run the ACC power (yellow wire) from the front. Run the 12V and GND lines directly from the battery in the trunk. Put a fuse on the 12V line run as close to the battery terminal as possible. Use a 15A for the 150W opus or a 10A for the 90W OPUS.
There arent really any circuits in the BMW that have enough overhead to accomidate the 8 to 13A that the OPUS psu's need, so running the seperate circuit for the opus is not really only a suggestion -- it's fairly essential.
Do I have this right?
- Run 12v and Ground lines from the battery to the Opus in the Trunk (not sure on gauge)
- 10amp Fuse on the 12v line from the battery to the Opus (not entirely sure what this entails, but I will
- Run 16-18 guage ACC power line from the dash for the HK amp in the trunk (for auto-on)
- Run VGA to the dash
- Run USB to the dash
Thanks!
