Notices
Old 05-17-2004, 05:32 AM   #1
Lightbulb measure Watts consumed
This tool will finally answer everyone's question:
"Is 150W enough to power my system?"
These guys make a product called Watts Up? and it allows people to instantly measure how many Watts are being consumed by any 120V device. You simply plug this inbetween the source and the device and it reads out the power used, cost, and a bunch of other nice facts.
They have two versions, the regular and the Pro which has a serial connection to transfer data to your PC about power consumed over a period of time. The price is a bit steep but I think it will aleviate everyone's fear of whether 150W will be sufficient to power their PC rigs.
Anyone used one of these before? If I end up buying one I'll post some results.
hifiguy is offline   Reply With Quote
Advertisement Sponsored links
Old 05-17-2004, 07:20 AM   #2
weekendowel's Avatar
I have a similar thing but for 230 V instead (for use in Europe). It works very well. I use it to monitor how much energy are used in various battery based installations at my work.
weekendowel is offline   Reply With Quote
Old 05-17-2004, 11:12 AM   #3
Isn't a power supply rated on how many watts it "outputs", vs. "consumes"? So, with this device, one would use an estimation of Power supply efficiency to determine output wattage? Use 70% if no other info is available?
DavidL is offline   Reply With Quote
Old 05-17-2004, 11:38 AM   #4
Raw Wave
god_of_cpu's Avatar
Damn, yo $100... Just get yourself a good multimeter like this one for < $20 that will measure amps. To get wattage, just multiply by voltage. That one will be good up to 10 amps*12v = 120 watts. For a bit more you can get thisone that goes to 20 amps.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 05-17-2004, 02:44 PM   #5
Yes, you need to keep the efficiency of the PSU in mind when measuring the input Watts, and the efficiency varies with the load.
For measuring the input Wattage I love the Kill-A-Watt. It does volts, hz, amps, VA, Watts, kWh etc.
It is an excellent tool. Check the power consumption of that old fridge/freezer in the garage. You will be surprised!
http://froogle.google.com/froogle?q=...b=ff&scoring=p
NewTechFool is offline   Reply With Quote
Old 06-12-2004, 05:46 PM   #6
i convinced my work to get me the Watts-Up? tool so I've posted a few preliminary readings on my site.
My desktop consists of:
Enermax 350W FCA
XP1900
MSI Turbo2
1GB SDRAM
MSI FX5600
M-audio 7.1 PCI
Netgear 10/100 NIC
Samsung 52x CDR/CDRW/DVD-ROM
Maxtor 60GB 7200 2MB
Maxtor 250GB 7200 8MB
NewQ Platinum
The average idle reading was 149W into the PSU. More readings to follow!
Old 06-13-2004, 02:27 PM   #7
big problem is thats what the PSU DRAW's. and ATX one's are not vary efficent. so lets say you need 120w to run your system. and its drawing 120w. the ATX PSU lets say a 300w one. it might be drawing 200w since its only 70% efficent
beaverpants is offline   Reply With Quote
Old 06-13-2004, 02:42 PM   #8
Mac Car Moderator
kandyman676's Avatar
the only problem i have @ Watts Up is it is all AC current measurements. however, its benefit is the data capturing via the serial port.
too bad they don't make one for DC applications.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 06-16-2004, 02:34 AM   #9
Test 1: 76W average into Enermax 350W PSU
MicroATX MSI KM4M
Duron 1.6 .13um
80mm Thermaltake Smart Fan
512 2700 Micron DDR
WD 80 7200 8mb
Pioneer 16x DVD-ROM
3COM PCI 11a/b/g
Test 2: 101W average
Added 8x AGP MSI FX5600
Test 3: 2W average
Removed AGP and placed PC in Hibernate
Test 4: Standby Mode
So I put my PC on standby in the middle of playing an mp3 and found the following:
Watts consumed: 35
CPU remains on
Wifi pci remains on
USB 2.0 hub remains on
Mouse LED remains on
Coming back from standby took under 1 second (freshly formatted machine) and music continued to play even before Lilliput came on!
If it wasn't for the 35W drain I'd definitely used Standby over Hibernate.
How Many Watts? dummptyhummpty Power Supplies 6 04-26-2004 02:19 PM
How many watts do I need? maxcosity General Hardware Discussion 1 04-21-2003 02:10 AM
How do I know how many Watts?? HunterC47 General Hardware Discussion 2 07-20-2000 12:13 AM
Inverter 150 watts prado_sergio General Hardware Discussion 1 11-09-1999 03:24 AM
Inverter 120 watts prado_sergio General Hardware Discussion 0 11-09-1999 02:50 AM
