Old 05-20-2004, 06:01 PM   #1
jusatry's Avatar
jusatry is on a distinguished road
can i combine 2 PSU to get more power?
more specifically, im trying to power a laptop in the car - but its gonna be a behemoth: Inspiron 8200 - 1.6Ghz processer, 30 GB HDD, 256 MB ram, plus a DVD drive. Im concerned that the radio shack power adaptor i have (universal laptop power adaptor) will not be able to supply enough amperage @ the 20V the dell needs.
Can i get a second one (prob off ebay or something), set it to 20V too, and splice the wires together AFTER the regulators? So essentialy running them in parrallel?
Opinions or advice welcome - thanks in advance.
jusatry is offline   Reply With Quote
Old 05-20-2004, 06:42 PM   #2
pip
pip's Avatar
pip is on a distinguished road
Not a good idea, but one of those replacement power supplies from Radio Shack might do the trick: ICE power adapter
• All-in-one AC/DC notebook power adapter
• Plugs into standard vehcile power outlet
• Fits aircraft in-flight outlets
• Compatible with standard AC outlets
• Designed specifically for use with Apple, Compaq/HP, Dell, Fujitsu, Gateway, IBM, Panasonic, Sony, Toshiba and Winbook notebooks
• AC input: 100-230V
• DC input: 11.5-16V, determined by individual itips Smart Connector
• Continuous power output: up to 70W
• Comes with 3-ft. AC input cord, 3-ft. DC input cord and 6-ft. DC output cord
• Dimensions: (LWH) 5.4x2.15x0.85" (13.7x5.5x2.1cm)
• Weight: 6.8 oz. (192.8g)
If 70W isn't enough (though I think it is for an 8200) then check out Powerstream, I belive they do 100W supplies.
pip is offline   Reply With Quote
Old 05-20-2004, 07:55 PM   #3
jusatry's Avatar
i have one from radio shack that is 60 watts/3.75 amps and that just did not seem like enough. I guess i will find out - just out of curiousity, why can i not run two supplies together? (just because i am interested, dont know much about power/electricity so im gonna take your word for it, but i was just wondering....)
thanks for the links and info!
Old 05-20-2004, 10:09 PM   #4
StationRocket's Avatar
StationRocket is on a distinguished road
Two things
To figure out what you need just flip over the AC/DC supply that came with the laptop and read what's printed there to see how many amps at 20v it is rated for. That will tell you what you need from your DC/DC
As far as running two DC/DC in parallel it's definatly a bed idea. They will very likley be regulating at very slightly different voltages which could lead to one of them trying to do all the work and the other doing nothing. If you're gonna get another DC/DC just get one that can handle the sys itself.
StationRocket is offline   Reply With Quote
xenarc tsv power from psu molex? icet Power Supplies 0 05-19-2004 12:41 PM
mobo does not support resume on power loss ashbosh General Hardware Discussion 3 05-18-2004 10:49 AM
Power Question/Setup Question, minibook pc seamonkey420 Newbie 4 05-17-2004 10:47 PM
Power problems with car computer :( Bitflip General Hardware Discussion 9 04-26-2004 04:13 PM
PSU power over speaker wire??? Defiler Power Supplies 12 02-20-2003 07:48 PM
