Notices
Old 05-20-2004, 06:42 PM   #1
6 amps running prime95
I bench tested my setup today. It's a single board computer with an onboard LCD controller, a pentium 3 800, 256 megs pc133 , 20 gig 7200rpm hard drive, a teac notebook cd-rw, and a 12" LCD. I'm using a 250 watt AT power supply run off a 400 watt inverter.
The current draw was much lower than I thought it would be. The inverter pulled 4 amps at 12.4 volts when the rig was idle. i ran prime95 and when the cpu was loaded it pulled 6 amps at 12.2 volts. That means the whole rig only pulled 72 watts at full load!?!?!? 72 watts at the battery?!?!?!?!
could this be true?
turbochris is offline   Reply With Quote
Old 05-21-2004, 07:50 AM   #2
thats low, but a p3 800mhz doesn't draw much "watts" (20.8watt) and your lcd wont draw more then 20watts orso, so it could be possible yeah
Newbee, sorry for my bad english. lol
Trying to built a carmp3 systeem
own psu: max788, pt5071, pt5024
PASware is offline   Reply With Quote
Old 05-21-2004, 07:57 AM   #3
Raw Wave
Rob Withey's Avatar
Doesn't sound completely unreasonable. My P233MMX setup draws about 2.5A under load with a VFD.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 05-21-2004, 04:02 PM   #4
I figured stepping the voltage up to AC and then back down to dc would have killed the effeciency.
Old 05-21-2004, 05:30 PM   #5
Efficiencies are heavily dependent on the brand of inverters and also what you are powering. I've seen some DC-AC inverters as low as 70% (no-namers and cheapies) which claim '90%' efficiency and some which work as advertised near 93%-95% efficiency. With inverters, you do get what you pay for.
Kermee is offline   Reply With Quote
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
Running Two Computers? dapilot Power Supplies 9 04-15-2004 09:14 AM
Anyone running their computer AND amps off the Opus? brrman Power Supplies 12 12-09-2003 02:30 AM
How long can an opus power the computer running without Durango running?? nolmscheid Power Supplies 9 11-01-2002 12:21 PM
Questions about running cable, also powering questions dudah85 General Hardware Discussion 29 05-31-2001 10:36 AM
