Old 05-27-2004, 06:51 AM   #1
weekendowel's Avatar
weekendowel is on a distinguished road
New shutdown controller - software
This is a solution everybody can do I think .
I wrote this prog to shutdown/hibernate your computer when you short pin 4 and 8 on the comport. There are instructions in the zip file.
Use it as much as you want and tell me if I should add something or do something different.
Shutdown Controller
weekendowel is offline   Reply With Quote
Old 05-27-2004, 01:39 PM   #2
dodgetimes2's Avatar
dodgetimes2 is on a distinguished road
Works great!!! I was thinking that if you could some how have the serial port send out another signal a little bit after the shutdown occurs that could control a relay that could turn off an inverter. That would be a kick *** program for all of us with inverters. Nice work.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 05-27-2004, 01:52 PM   #3
Take a relay that is triggered by the 12V of your power supply and by the ACC line from your car, you have to put a diode in between, and feed the Inverter/PSU thru it. And set the motherboard BIOS to startup after powerloss.
Old 05-27-2004, 06:05 PM   #4
rpartner is on a distinguished road
This is a very good function. I am running my carputer on EPIA-TC10000 and it has onboard dc-dc with two pin 12V output. Maybe this could control the relay?
rpartner is offline   Reply With Quote
Old 05-28-2004, 01:32 AM   #5
Diode, why didn't I think of that.
Old 05-28-2004, 01:37 AM   #6
CRCinAU is on a distinguished road
I'm assuming you couldn't use this if you have a GPS already on the com port? or can it co-exist with other equipment?
CRCinAU is offline   Reply With Quote
Old 05-28-2004, 01:43 AM   #7
vcbb5's Avatar
vcbb5
could someone draw a fast schematic for dumb people?
My Mazda 3s
My Mazda 3s on Car Domain
[||||||||||||||||||--] (90%)
vcbb5 is offline   Reply With Quote
Old 05-28-2004, 07:54 AM   #8
Something like this should work!!
Old 05-28-2004, 07:58 AM   #9
CRCinAU, it wont work to have it on the same comport, but thereīs mostly 2 comports on every motherboards, you just need a cable for it, no need for an extra card or something, check in your motherboard manual
Old 05-29-2004, 12:34 PM   #10
Updated shutdown controller:
Shutdown Controller
It will now pause winamp and turn off your screen when you short Pin 4 - 8.
I use it like this:
When I turn off my car it will pause winamp and turn off my screen but leave my computer running for 10 min, if I get back before 10 min it will directly unpause winamp and turn on my screen.
Old 05-31-2004, 03:32 AM   #11
d_sellers1's Avatar
d_sellers1 is on a distinguished road
Any got any pics on how this is exactly set up. I'm not picturing it in my head.
Derek
d_sellers1 is offline   Reply With Quote
Old 05-31-2004, 10:03 AM   #12
vcbb5's Avatar
vcbb5
I'm trying to get a little diagram, but idk how good it is, and if it will work. I also don't know what parts to use (what relays to buy, what capacitor to buy). NO one at any radio shacks have a clue, and no response yet on the board .
I've been posting it here.
I also think I'm going to go through the switch that actually turns on the inverter, instead of the power line that goes to the inverter. That should make the capacitor smaller that i need to use in front of it (for shutdown delay). I've also thought about a small 12v battery infront, but that would take a LONG time to shutdown the computer (my UPS batt lasts 5-15 mins, probably 15-30 on a low power system.)
My Mazda 3s
Old 05-31-2004, 11:26 AM   #13
I donīt believe you need that capacitor at all !!
Connect it like this and set your motherboard to startup at powerloss:
Old 05-31-2004, 01:47 PM   #14
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
But if windows hangs on shutdown = inverter stays on = possible flat battery!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 05-31-2004, 02:27 PM   #15
Yes, thatīs a possibillity, but it will hardly happen on a computer in a car. On a computer at home or office, when you are installing/deinstalling a lot of programs and so on thereīs a risk the machine will hang from time to time, but in your car you will have a handful of programs and you minimize the risks of unwanted hanging.
prob with mucha shutdown controller geebee Power Supplies 7 12-08-2004 10:30 AM
Keyless Entry Shutdown Controller Sinorm Power Supplies 2 04-07-2004 09:30 PM
What do you want in a shutdown controller? meddler Power Supplies 0 02-12-2004 03:40 AM
ATX shutdown controller kit / assembled for sale Mastero Classified Archive 22 01-27-2004 02:33 PM
software for mp3ondemand shutdown controller! mykolJay Software & Software Development 1 07-08-2002 04:17 PM
