08-20-2006, 07:53 PM
#136
Well, I hate to do it, but I have to revive a very old thread back from the dead
I made the circuit described in this thread, and it all works flawlessly. I used three 2200uf caps, and it gives me two minutes and thirty-two seconds (2:32) worth of time before it shuts off the relay.
But, my issue is my inverter. When everything is plugged in, and I start my car, my inverter cant handle the crank very well, and my computer doesnt get passed the bios (post) screen and it locks up cold.
So what I need to do is make a delay of about 4 or 5 seconds before the circuit gives power to the inverter. That way the car will be fully started before everything kicks on. That would solve my problem. But, I dont know how to do that
Does anybody have any ideas or insight on how to fix this?
I greatly apreciate any help or comments... Thanks In Advance!
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Everything is in the car and working.
I painted the cilpboard mount and it looks good.
Shutdown/Startup is working excellent!
View My Progress Here
08-22-2006, 07:56 PM
#137
Use a timer on the input to the 30-amp relay... Lots of info about them out there on the web. Some of these circuits might help. You're looking for one with an output of OFF, time delay, then On... I'm sure someone's diagrammed that somewhere. http://home.cogeco.ca/~rpaisley4/LM555.html
09-02-2006, 04:28 AM
#138
I found a power on delay circuit with some caps and resistors, but for some reason it doesnt work like the description reads
http://ourworld.compuserve.com/homep....htm#delay.gif
Can anybody give me some advice on how to use this? I wired it in, from what I understand, to be the right way, and it only works for about a half a second. When I used a bigger capacitor (6800 micro farad) the delay is about 40 seconds. I wired an LED to test and see the power delay output, and the LED doesnt turn on and off like I think it should. It turns on but verry sloowly... And slowly turns off.... Is that the way it should work?
Thanks in advance for any advice. I apreciate it.
Carputer Progress
[||||||||||] 100%
Finally Installed!!
10-03-2006, 06:57 PM
#139
Hi Mate,
Did you make the circuit diagram with corrections as posted by lexanite (i.e. the 03-09-2006 10:30 PM post)?
Cheers,
Scott.
10-04-2006, 04:36 AM
#140
Quote: Originally Posted by the_realscott
Hi Mate,
Cheers,
Scott.
Yep, sure did. Like I said the shutdown works perfectly, but I need a delay of some sort.
I ended up fixing it all. I used the start up delay I posted above and used that on a trigger relay that powers the shutdown controller...
Now I have Key>5 Second Delay> PC Powers Up|Take Key Out>Inverter Stays On For A Few Minutes>Computer Completely Shuts Down>Inverter Dies
All is perfect, and working very well...
Carputer Progress
[||||||||||] 100%
Finally Installed!!
10-05-2006, 11:21 PM
#141
Congratulations we87! Now I must ask for Pics! That, or you must appear at a meet to show off.
Those are the rules....
(change your sig, btw)
10-06-2006, 05:16 AM
#142
I agree, I need to post my pictures and update my thread. I just wanted to make sure I actually had everything working before I went around bragging about it  hehe
Carputer Progress
[||||||||||] 100%
Finally Installed!!
05-05-2007, 05:09 PM
#143
Holy back from the dead batman.
I almost posted up a new thread but I thought it belonged better here.
I got a couple questions if someone doesn't mind looking over this design and tell me if it is correct.
Background:
What I'm trying to do is delay the inverter starting up for around 3-5 seconds, auto shutdown via pin-8, and delay power cutoff to the inverter by about 1-2 minutes. I might add in a delay to my amps later, but thats another story. Basically what we87 did, I just want to make sure it's right before I start building.
Main Question:
If anyone might have an idea on a transistor I could use to replace a 2N3053 since the shack doesn't sell them. I can pick up the rest at the shack. Once I'm finished I hope to post the sheet I'm working on with part numbers and a price list and the sources I used so that others could use this in the future, however I want to make sure it's right before I go and start building.
Anyway here is what I have at the moment. And I know, led's L1 and L2 aren't labeled. I want to change those to 5mm by the way, thats the reason for the increase in the value of C3. R4's value isn't listed due to having to change it to two 4.7k in series due to the shack not having 9.2k resistors and I just got lazy and haven't changed it yet.
Let me know what you all think.
05-06-2007, 07:40 AM
#144
I'm not sure what the LEDs are for but I think the first one will slow the charge of C2 & C3 much more than you want. Remove them both, and just tie them to each point with a resistor, and ground the other end.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
05-06-2007, 02:33 PM
#145
I was just going off of the circuit posted in this thread earlier, the LEDs are for monitoring. I just increased them to 5mm for my purpose.
Quote: Originally Posted by PatO
Optional areas are in pink (led's to make the circuit flashy).
05-10-2007, 08:21 PM
#146
Nice Schematic
I know I had the exact same issues with the 2N3032 Transistor, but now I cant remember which one I used in place of it... When I have time Ill look at my controller in the car and hopefully Ill be able to tell which transistors is which on there. But I bet if you Google around for "2n3053 Replacement Alternative" you'll find what your looking for. The main thing to remember and keep in mind is which transistor is a NPN and which transistor is a PNP. Thats the main difference from what I found anyhow...
Also, I'm not sure if you've seen it or not, but theres a little app you can run and when you short pin4 and pin8 on your comport (easily done with a relay) the computer automatically shuts down. Thats what I use in place of the +5v going into the com port. That thread is here: http://www.mp3car.com/vbulletin/powe...-software.html
Carputer Progress
[||||||||||] 100%
Finally Installed!!
05-10-2007, 11:13 PM
#147
we87: Yeah I looked at it when you e-mailed me, but thought this method may be a bit easier and it's one less program to run on the pc which is only a 1.3 celey with 128mb ram (upgrading that once I get it setup).
I've looked for a replacement but was wondering what others were using. Thats just part of the schematic, I got the parts list and the sources on the main schematic image with total prices and shack part numbers.
05-10-2007, 11:17 PM
#148
Self proclaimed spoon feeder
My solution was to use a switch.... cheap and very effective
TruckinMP3
Read the FAQ!
05-11-2007, 01:20 AM
#149
Yeah but I hate having to remember to press power and wait in my truck for the pc to turn off.
Reason: adding something
05-11-2007, 04:19 AM
#150
make a tank circuit, this will allow you to crank your engine and keep the computer running on a back up battery.
Search tank circuits on this forum.
It works
| Thread Tools |
| Display Modes |
Linear Mode
