Old 05-28-2004, 11:50 AM   #16
vcbb5's Avatar
weekendowel- love the program
My Mazda 3s
My Mazda 3s on Car Domain
[||||||||||||||||||--] (90%)
vcbb5 is offline   Reply With Quote
Old 05-28-2004, 12:06 PM   #17
Confusion Master
Enforcer's Avatar
Why is everyone messing with the 8 pin on the serial port. all you need to do is have the PC set to hibernate, standby or switch off when the power button is pressed. Then have a lead that goes to the power switch connector on the M/B going to a relay that will monetarily close the switch.
Enforcer is offline   Reply With Quote
Old 05-29-2004, 01:49 AM   #18
weekendowel's Avatar
The problem is with the relay that should send a pulse to the motherboard, if you just turn on your ignition and then turn it off right away, then the PC will startup and stay on, when you start your car the PC will go to hibernate. With the comport idea it can´t go in the wrong phase.
weekendowel is offline   Reply With Quote
Old 05-29-2004, 02:19 AM   #19
starfox's Avatar
Nice simple idea, hope it all works out
starfox is offline   Reply With Quote
Old 05-29-2004, 07:39 AM   #20
Raw Wave
Sorry for the delay the forum is always down and cant post until now.
Diagram of external WOM trigger on COM port :
http://english.aopen.com.tw/tech/techinside/wom.htm
UPS - COM port pin definition :
http://support.microsoft.com/default...kb;en-us;98885
Wake test :
http://www.microsoft.com/HWDEV/Onnow...d/waketest.htm
COM port pin out :
http://www.infonewsindia.com/pinout/#5
Not sure what volatge you can apply on "ring indicator" but Ill assume it should follow the RS232 signalling spec. Theres plenty of info on net just it
Ricky327 is offline   Reply With Quote
Old 05-29-2004, 07:57 AM   #21
vcbb5's Avatar
Does anyone know what kind of relays and capacitor Iwould need for this diagram? (preferably from www.radioshack.com, cause I'm goin there today. )
My Mazda 3s
Old 05-31-2004, 02:40 PM   #22
Anyone got more technical, electronic schematics. Where does pin 4 and 8 come from. Cant you just use a smal switch to short the two, instead of the relay.
elec999 is offline   Reply With Quote
Old 05-31-2004, 02:49 PM   #23
Ofcourse you could have a pushbutton to short them, any short will do
Old 05-31-2004, 02:53 PM   #24
Raw Wave
Laidback's Avatar
I think we're trying to get around using a switch here!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-01-2004, 08:55 AM   #25
Well, Ill just sit back and wait for you smart people to figure this out for me, heh...
morgant6911 is offline   Reply With Quote
Old 06-01-2004, 08:58 AM   #26
vcbb5's Avatar
me too.........................
I was thinking two 1 amp relays if your going directly to the inverter's switch. I have no idea about the capacitor. I also don't know how to wire the relays.
My Mazda 3s
Old 11-29-2004, 09:51 PM   #27
joebagodoe's Avatar
Quote: Originally Posted by vcbb5
Does anyone know what kind of relays and capacitor I would need for this diagram? (Preferably from www.radioshack.com, cause I'm goin there today. )
Mee tooo. I am battling a ground loop but want to move forward to get this going. What relays would we be using to accomplish what this scematic displays and how does one build the capacitor? I've looked and there really isn't anything definitive. Sorry I'm such a noob, I just want to get this completed!
Today I stuffed some dolls full of dead rats I put in the blender. I'm wondering if maybe, there really is something wrong with me.
joebagodoe is offline   Reply With Quote
Old 11-29-2004, 10:44 PM   #28
vcbb5's Avatar
http://www.vcbb10.info/ShutdownController
that's the most recent with pics of my shuttle wired up. I didn't use a cap, so no delay, but it shuts the inverter off after the computer shuts down (leaves on if computer hangs, but that shouldn't happen...much )
Also uses this for com port trigger: http://www.mp3car.com/vbulletin/show...own+controller
more in-depth info: http://www.mp3car.com/vbulletin/show...&page=3&pp=10&
My Mazda 3s
Old 04-26-2005, 08:17 PM   #29
PatO's Avatar
Just reviving a great thread....
Some of you appear to be stumped about the power off delay in this circuit. I've been working on my own shutdown controller do-hickey and have this clip to share. The entire thing isn't ready yet, but I thought I'd share this portion.
All parts are available at Rat Shack, and it's been tested and works fine. Not tested in a car or on a computer, but a breadboard is close, isn't it?
The caps hold the base of the transistor charged for a while. Transistor powers the relay. Very simple. Adjust the caps for your desired time.
My comp does a full shutdown in around 1 minute, so I shot for 1m 15sec+, hence the caps I chose. I haven't tested it at 14+V in a car, more time, I guess...
The +12 input will charge until unlatched, then the caps determine the time until the relay is shut off.
Optional areas are in pink (led's to make the circuit flashy).
http://jeepmp3.home.comcast.net
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 07-26-2005, 09:45 PM   #30
Ok I have said this a few times but is it possible for people to take pictures of their ghetto shutdown controller? Or make a list of parts so a newb can have a DIY. I don't know how to read wiring diagrams so real pictures would be very helpful...thanks
MikeyTampa is offline   Reply With Quote
Voice control for Winamp VoodooVoice Software & Software Development 11 08-01-2006 05:19 PM
cd changer control to control the pc babas151 General Hardware Discussion 6 10-25-2004 11:21 PM
Kenwood KDC-W6527 radio CD/MP3/WMA receiver & remote control chewiee Car Audio 3 05-26-2004 04:08 AM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-03-2003 11:00 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
