Notices
Old 06-03-2004, 09:48 PM   #1
Opus 150W PS
Ok, call me stupid but when you all have an Opus power supply and you build your pc. How do you power it up without having to build it in the car? Do you all use an AC/DC adapter? Or do you just power up an old AC ATX power supply and leave it sitting outside the box while you build it and then plug back in your opus when you go back out to the car.
Bryan22024 is offline   Reply With Quote
Old 06-03-2004, 09:54 PM   #2
Super Moderator
xBrady's Avatar
I am built mine using the regular ATX power supply. What I am going to do when i install the opus is Have both power supplies in the case. I have enough room so when I need to bring it inside I will just switch out the motherboard connectors.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 06-03-2004, 09:54 PM   #3
ashbosh's Avatar
well from what what I understand, its better to use the ATX power supply to test the dc-dc psu. You can use the 12V rail rom ATX psu to power and test dc-dc psu like opus. The AC/DC adapter may not provide enough amps to power the mobo.
Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
Holux G210
03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
ashbosh is offline   Reply With Quote
Old 06-03-2004, 09:56 PM   #4
ashbosh's Avatar
Damn, we both post at the same exact time!!!!!
Holux G210
Old 06-04-2004, 11:01 AM   #5
I actually had to cheat when I wanted to test my 90W Opus...
The problem was that my el-cheapo ATX power supplies were only giving ~11.5 V on the 12V line, but I think my Opus was waiting for 12.5V+ on the IGN line, and so I needed to get the voltage higher. Instead of going from ground (0V) to +12V (12 - 0 = 12V) I went from the -12V to the +3.3V (3.3-(-12) = 15.3)and was able to test the Opus before putting it in the car.
First, you can turn an ATX power supply on without a motherboard by shorting pins 13 + 14 (blk + green).
To get 15.3 (it wound up ~ 14.5 for my cheap PSU), connect the 3.3V on the Opus Ignition (Yellow?) and connect the -12V to the Opus Ground (Black).
Sensor is offline   Reply With Quote
Old 06-04-2004, 08:12 PM   #6
Ok so I know where to get 12v and 5v from the hard drive power leads but where do you get the -12v and the 3.3v from.
Old 06-05-2004, 03:06 PM   #7
the motherboard conector has -12 and 3.3
beaverpants is offline   Reply With Quote
Old 06-05-2004, 03:22 PM   #8
Confusion Master
Enforcer's Avatar
I have a 2-3 Amp 13.8 DC supply which I got from Tandy/Radio Shack.
Use for all my 12 Testing before it goes in the car. Car stereos, PC, Phone kits etc.
Enforcer is online now   Reply With Quote
Old 06-06-2004, 12:08 PM   #9
http://www.pcguide.com/ref/power/sup...erboard-c.html
The diagram of an ATX motherboard power connector is about half-way down. If you have a voltmeter to test beforehand, I'd recommend you do -- alternately, you could do as Byron says and buy something from RadioShack. ^^
Troubleshooting 150W Opus (turns off after 20-30 mins) [iG] Power Supplies 8 06-05-2004 11:13 AM
Closed - Possible Opus Group Buy BoraXP Classified Archive 319 05-18-2004 11:03 AM
Will a 150W OPUS power this? mbkowns Power Supplies 1 04-14-2004 03:17 PM
New OPUS 150w not working? kylechughes Power Supplies 4 01-27-2004 03:21 AM
EPIA M6000 and Opus PS millec Power Supplies 2 01-09-2003 01:12 PM
