Notices
Old 06-06-2004, 09:41 AM   #1
Newb question about standard psu's
hi guys,
im a complete newb on the carpc seen, hence the name, but ive got a question about using standard psu's.
ill be building my pc under a false floor in the trunk, with lots of cooling fans etc, but because i wont be restrained to a certain size i would like to use an ATX board with a decent CPU, gfx card etc etc. So, my question is, can I use a standard PSU, and if so how? I know ill need an inverter to convert the 12v feed to 240v (UK) but how do you control the startup and shut down functions ala Opus?
cheers
newbiemcnewb is offline   Reply With Quote
Old 06-06-2004, 09:48 AM   #2
binary.h4x's Avatar
here you go! http://www.roshanindustries.com/carmp3/sdc.htm
binary.h4x is offline   Reply With Quote
Old 06-06-2004, 10:05 AM   #3
thankyou sir!!!
just to clarify, the power chain would be
battery-shut down controller-inverter-psu-mobo
that sound about right?
Old 06-06-2004, 10:13 AM   #4
no1knows's Avatar
correct, u could also use the ITPS, u can get it from linitx.com, they are based in the UK. Sounds like your going for the exact setup i have.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 06-06-2004, 11:05 AM   #5
ive heard about inverters causing noise when it comes to using fm modulators or something. ill be running the sound straight into my amps, so will it cause a problem, what is yours like?
opus powersupply question (newb) crash893 Power Supplies 15 02-01-2005 07:07 AM
Newb LCD question TiziteLayinLow LCD/Display 2 03-04-2004 06:28 PM
opus powersupply question (newb) crash893 Power Supplies 1 01-06-2004 04:36 PM
newb grounding question... bstanton General Hardware Discussion 6 01-15-2003 02:02 PM
Question about DC DC PSU's TMDJ Power Supplies 8 11-04-2002 05:14 PM
