Old 06-09-2004, 07:11 PM   #1
Watts? enough power?
im gonna use a inverter to power my 120W power supply.
im runng a celeron 366 which i will upgrade to a 500 or 600 later.
how many watts do i need on the inverter?
also does the wattage affect how many USB devices i can use?
im planning to put in LAN, WIFI, HD, CD drive, Keyboard, Mouse,GPS, touchscreen,and phone through USB. will i have any trouble with power?
dannn is offline   Reply With Quote
Old 06-09-2004, 07:16 PM   #2
no1knows's Avatar
if your using a 120W power supply then you will get away with a 150W inverter. Whether your pwoer supply will be able to handle all that is the question. I would say it should be ok, depending on how many USB devices, whether or not yr using laptop/desktop HD/CD drives.
Just get an invertor with continuous power of above your power supply and you'll be fine (as long as u keep it cool).
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 06-30-2004, 10:50 AM   #3
i bought a Power On Board 350 watt inverter and for some reason the overload/low battery light keeps coming on when i plug in the 120w power supply. i dont even turn it on rught when i plug it in the inverter stops working.
Old 06-30-2004, 11:03 AM   #4
Mine does the same, just put a 22ohm resistor in after the inverter and before the power suply, then it works.!
Mine works that way for 3month now.
Its the power suply there are making some high sparks when the power are aplied
clemen is offline   Reply With Quote
Old 06-30-2004, 11:15 AM   #5
robiewp's Avatar
no! evil evil evil!!!!!
where is your inverter connected? it seems to me it's not connected over a low enough gauge wire (or there's a bad connection somewhere).
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
Old 06-30-2004, 11:44 AM   #6
pip
pip's Avatar
Are you plugging this into a cigarette lighter socket? DONT!
Run a fairly stout guage wire to the battery, with a fuse near the battery. You are probably not able to draw enough power through the cigarette lighter to keep the inverter happy.
pip is offline   Reply With Quote
Old 06-30-2004, 11:52 AM   #7
robiewp's Avatar
most cig. lighters are rated for 20 amps ~ 240 watts. there's nothing wrong with using the cig. lighter for many applications, but your lead from the lighter socket or any other power source does.
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 06:10 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Install coming up... but Power questions technopsych Power Supplies 2 04-14-2004 07:16 PM
Simple Idea for keeping power to inverter while cranking.... syclone477 Power Supplies 1 03-23-2004 09:03 AM
ATX 150 to 300 Watts DC-DC power supply Macgyver777 Power Supplies 3 01-25-2002 03:34 PM
