The MP3car.com Store
Thread Tools Display Modes
Old 06-14-2004, 06:08 PM   #1
Vehicle: Chevrolet Suburban 1995
My Photos: (0)
Problem with tank battery - any good Plan B?
I have a Chevy Sub, so I had room for a second battery tray. I put one in, and a battery, and hooked it all up to a battery separator (one of those thingies that looks like a CPU cooler, with one input and two separated outputs). But the extra battery gets drained. I think I know why as well: Right now I have the regular battery hooked directly to the alternator (since it wouldn't charge when it didn't have access to battery power), but the tank battery gets it's charge from that separator. The voltage loss in that separator is around 0.6 V, and that's obviously exactly the loss that will stop it from working. I have an idea, but I wanted to ask if this will work first:
I can hoop up a thin cable with a relay and a fuse on it from the alternator to the tank battery. The relay will be wired to something (perhaps the driving lights) so it's only open when the keys are in. Then it won't drain the start battery while the keys are out. That will keep the charging voltage up. But will starting the car make that cable burn up or the fuse blow? My main problem and cause to get that extra battery was that every time I started the car the computer had to be shut down (into hibernation). With the extra battery it won't. But that doesen't really help if I can't go into the gas station to pay with the computer running since the tank battery is almost empty. Any help would be appreciated!
Tor - The MediaSUV
Mastiff is offline   Reply With Quote
Sponsored Links
Old 06-14-2004, 06:11 PM   #2
no1knows's Avatar
Vehicle: 94 Honda Civic LSi Hatch
My Photos: (0)
You can setup a relay with yr ACC line which is switched on while the keys are turned, except when the engine is cranking (in most cars).
So, this will ensure that your second battery will be charged only when your keys are in the ignition but not when cranking which could cause high currents coming from yr tank battery. You will need a resistor inline with this cable to limit the charging current to the backup battery, the size of the resistor depends on the size of yr backup battery. As far as i understand your problem, that will solve everything.
HTH
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 06-14-2004, 06:19 PM   #3
My Photos: (0)
Man, you're fast! OK, I understand part of what you're saying, but not all. I will check out that ACC line, and maybe use dual relays since I want the line to be open onlye when the car is running. So if I use one relay on the ACC and one one something like the driving lights (they only have power in on position, not ACC) that may actually work! Thanks! And now that I think about dual relays I have an even better idea: a relay that's hooked up to the starter engine's trigger voltage, so it breaks power when it's cranked! I probably wouldn't have thought about that without your suggestion!
But why a resistor? The battery is always in use since I have the stereo system and computer hooked up exclusively to that. I don't always use the computer (and my wife seldom uses it), but I always use the stereo. Do I still need a resistor?
Tor - The MediaSUV
Old 06-14-2004, 09:10 PM   #4
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
Take a look at this and this to get more ideas. I'm working on something right now using both designs if the relays aren't out of stock this time.
XPort 1.22 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
tank circuit TiTUS General Hardware Discussion 10 09-07-2003 05:05 PM
Can I put an extra battery in my Chevy? Mastiff Power Supplies 12 04-04-2003 02:19 PM
Invertor problem - plz help! hasato Power Supplies 2 08-26-2002 11:07 PM
Sproggy type power good problem eugenen Power Supplies 0 08-08-2002 08:47 PM
System Restarts whenever I start my car Blue Falcon Power Supplies 24 06-25-2001 05:15 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
