Notices
Old 06-16-2004, 08:08 AM   #1
Power drain on battery...
I drive a Pug 206 and am working on a (pretty basic due to finances) carputer for the little sucker.
I had a Seat Ibiza and ran a 150W inverter and an old P75 in it without problems, after a while i upgraded to a 300W inverter and a new pc... And I started to have some problems with my battery. Now I am pretty sure this was due to a problem with the car rather than the inverter as the problems remained after I removed the carputer...
But just to be safe I'm wondering if any of you guys have run a simlar sized inverter on a similar sized car? Have you had any problems etc with it? Could the alternator handle running the pc, lights, heater etc and still charge the battery ok?
all info is useful!
Ormo is offline   Reply With Quote
Old 06-22-2004, 04:00 PM   #2
Exclamation Same question ehre also
Same question here (almost), does a 300W inverter drain the battery? How about when the PC is off?
yuprules is offline   Reply With Quote
Old 06-23-2004, 01:33 AM   #3
When an inverter is 'On' but there is no load connected to it, the inverter will still usually consume a bit of power. Usually less than <1A but after a week or so if you don't use your car, your battery will probably be drained considerably.
Kermee is offline   Reply With Quote
Old 06-23-2004, 01:40 AM   #4
I have the same question. But I have a ITPS/PW70A will that combo consume any when the computer is off?
storm is offline   Reply With Quote
Can I put an extra battery in my Chevy? Mastiff Power Supplies 14 11-04-2008 12:45 PM
Will leaving Windows in Standby drain battery? slffl Power Supplies 34 08-03-2004 10:57 PM
If computer hangs, and constant current draw power issues Nic Power Supplies 0 06-14-2004 11:36 PM
Mini-box.com delivers the tiniest mini-ITX power solution to date petesonline Power Supplies 1 03-04-2004 07:02 AM
Here's an alternative power source.... A Boy and his Miata General Hardware Discussion 7 11-21-2000 12:44 PM
