01-06-2005, 08:52 PM
#91
Turns out my ISP has blocked all .tk due to the RIAA and Spam complaints.
I hope he is well after the disaster.
I would still like to buy a machine from him.
Julie
01-07-2005, 09:18 AM
#92
Registered User
Hey dont worry i am fine just been busy with work..... My site is fine
try this if your .tk is blocked HERE
Enjoy
Mastero
01-09-2005, 01:21 PM
#93
MySQL Error
Is anyone int he UK building one of these as i wondering what the part availablity was like if i went for the semi kit or would it just work out easier )and cheaper) to get the full kit as i suspect?
Cheers, Andy
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
01-09-2005, 06:10 PM
#94
MySQL Error
1 more thing, when i click ont he 4.5 semi kit detaisl i get page not found. I am going through the .com site as i have trouble with the .tk one too.
EDIT: opened the parts list and saw the items in red are not included int he semi kit
01-31-2005, 09:39 PM
#95
some more questions
1. i'm assuming the led next to the standby is the standby indicator :P, what is the other led (next to the 47uh inductor)?
2. atx-1 plugs into the motherboard's power pins?
3. where are the 5v, 3.3v, 5v standby, -5v, -12v outputs?
edit: found the -5, -12, is the 5v standby the one just labelled "STBY"?
4. where does the "power on/good" signals come from?
edit: are they "PG" and "PS_ON"?
5. where does vcc come from?
thanks a lot
02-01-2005, 10:19 AM
#96
MySQL Error
Quote:
some more questions
You are correct on the first one. The one next to the inductor is the power on indicator (PSU full on).
Plug ATX-1 into the mobo power switch. Then the header from the power button switch plug to ATX-2. Basically you are rerouting the power button switch.
3.3V is below MAX788 chips (3 holes), and 5V is below MAX787 (9 or 10 holes)
5V standby is label with STBY.
Power Good (Gray) = PG - below CMOS 4049 chip
Power ON (Green) = PS_ON - Between 12V relay and Sproggy relay.
What is Vcc? If you are talking about power in put, +12V In = Battery Red.
If you talking about ACC. That is going to the car keyswitch (Only on/hot when the key is insert and turn.). Cig lighter is one of them.
You are welcom
02-02-2005, 04:22 AM
#97
i was following the atx diagram from mastero's diy page, here:
http://www.roshanindustries.com/mp3p...ges/atxpin.jpg
thanks again mate
edit: btw, would you know if the max787 and national lm2678t-5.0 are comparible? (i.e. could i use the national chip instead, i can't get my hands on the max787s)
02-02-2005, 11:13 AM
#98
MySQL Error
Vcc on that diagram is the 5V (Orange).
If you want to build one base on National LM3678 chip, look for Mastero/Sproggy 4.0 thread. Some people report problem with those chips. That is why later Mastero change the board to use Max chip and called it 4.1 (I think). They are similar but not an identical replacement (7pins V 5 pins).
02-03-2005, 05:16 PM
#99
does anyone have a copy of the 4.0 component placement pdf?
edit: found a copy
02-07-2005, 03:43 AM
#100
finally finished building it! (and the max chip decided to arrive today  )
but now testing it, the 5v line under no load comes up as around 8v....... any ideas?
02-07-2005, 04:39 PM
#101
MySQL Error
Mine only output 4.98V under no load and engine off.
What is the reading for each chip?
Make sure the Max chips, Diode, and HS are all issolated.
02-07-2005, 06:41 PM
#102
the output of the max787s are 8v for both
although they are connected so...
also i'm pretty sure they're isolated
btw, why do they have to be isolated if they share the same ground anyway?
edit: all good now, there was a tiny short between the in/out of one of the 787s
02-13-2005, 10:36 PM
#103
my power supply decided not to work today...
i connect it up and nothing happens, so i'm expecting a broken relay
would it be the small 12v one?
02-14-2005, 10:22 AM
#104
MySQL Error
Check the voltage on all rails (3.3, 5.0, 12, -5, -12, PG, STBY)
02-14-2005, 10:45 PM
#105
none of the voltages are working, cos there is no relay "click" when i conect power which is why i think the relay is gone
although ps-on is at 0.23V
| Thread Tools |
| Display Modes |
Linear Mode
