Notices
Old 02-18-2005, 09:07 PM   #121
Quote: Originally Posted by Mastero
wats your point never ?
MAstero
ahh, thats its 180watts, not 250... I thought that point was fairly clear.
never_stock is offline   Reply With Quote
Old 02-22-2005, 02:02 AM   #122
i seem to get a 1KOhm short between the bottom two legs of the small 12v relay now, and this is preventing the sdc to work
but when j1 is jumpered the 5v stanby voltage is fine
do you reckon the relay is gone or not? :S
me and me lude is offline   Reply With Quote
Old 02-22-2005, 09:59 AM   #123
MySQL Error
MatrixPC's Avatar
Test the relay by itself.
De-solder the relay and test it outside. Just apply 12V and ground to the coil to see if it clicks.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-23-2005, 05:39 AM   #124
i applied 12, ground to the bottom two legs, and it clicks fine...
but i'm assuming these two shouldn't have a short
which legs of the relay are which anyway?
Old 02-24-2005, 12:51 AM   #125
MySQL Error
MatrixPC's Avatar
If it click, the relay is working.
Check the left most pin (and 10k res) of the BD677 to see if it read 5V when power is hook up. If it read 5V, but no ground on the middle pin, more likely the BD577 is toast. To check for ground on middle pin, check for continueity between middel and right pin (cuz right pin is connect to ground.)
Basicaly this is how the circuit flow.
- When the SDC is on, 5V is coming out of 74HC14 pin6 and thru 10k resistor. That signal (pin3) is switch the BD677 transistor to connect pin 1 and 2 together to send ground from pin1 to pin2 (middle). That ground is then switch/turn on the relay. The relay connect and send 12V (batt level) to 5V StandBy regulator (LM1084).
- J1 when shorted, will bypass the SDC's BD677 switch and directly switch/turn on the relay.
Old 02-24-2005, 01:29 AM   #126
Thumbs up Download java game without cable
http://www.ringringtone.com/
juteen is offline   Reply With Quote
Old 02-24-2005, 10:46 AM   #127
MySQL Error
MatrixPC's Avatar
What the **** does this **** has to do with this thread or this forum?
Old 02-25-2005, 02:38 AM   #128
hahahahhaah
there's a 1k resistance between the two bottom legs of the relay, so i guess i'll need a new one
Old 02-27-2005, 04:32 PM   #129
Kostas GOLF V's Avatar
HI!!
i'm new in this forum, can you help me?
I don't know where to find the Relays that 4,5 needs...
can i find them in digi-key.com?
or... where can i find them?
please explain me clearly becase i'm confused with them...
i'll be greatful if you give me the part numbers or sth...
THX A LOT!
Kostas GOLF V is offline   Reply With Quote
Old 02-27-2005, 08:39 PM   #130
if you're talking about the large one, i got mine from mouser, should be a link straight to it a page or two back in this thread
Old 02-28-2005, 06:00 PM   #131
ok thx for the large one!
what about the others?
Old 02-28-2005, 08:00 PM   #132
MySQL Error
MatrixPC's Avatar
If you read this thread from the beginning, you would of find this post.
I list all the compartible relays part # from NTE. NTE parts are very easy to get from most local electronic place. I am not sure about digikey on the other 2 relay, but they have the main relay. Part number are on the link I posted.
Old 02-28-2005, 08:37 PM   #133
Pyrotek's Avatar
Matrix, what video card are you using with that A7N8X?
I'm planning to pick up a 35w 2400+ for a similar setup. Debating about a mb with onboard video.
Pyrotek is offline   Reply With Quote
Old 03-01-2005, 02:34 AM   #134
MySQL Error
MatrixPC's Avatar
Onboard video. Quality is really good (DVD and winamp vis). I don't play graphic intensive game so I don't know if it can do it or not, but probably do well.
If you can get one of those mATX board that allow you to change FSB or multiplier either via jumper or BIOS. BioStar, and a new AOpen mATX board allow FSB change in BIOS. If you get the same Asus I got, you may have to do "wire mod" to get the mobo recognize correct CPU (mobile) speed.
Old 03-01-2005, 04:42 PM   #135
nFiniteTuning's Avatar
Any updates on this? I'm going 64bit on my XPCarputer and need a good psu to power her.
1987 Pontiac Fiero GT
XPCarputer Coming Soon
[IIIIIII---] 70% Complete
XPC Model SN41G2V2
AMD AthlonXP 1800+
2× Mushkin 256MB DDR
Pioneer DVDRW
80GB 7200RPM UltraATA HD
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
nFiniteTuning is offline   Reply With Quote
Mastero MK-4 ATX PSU with features. Mastero Power Supplies 407 08-23-2006 08:49 PM
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
Mastero MK-4 ATX PSU Semi kit for SALE Mastero Classified Archive 4 06-10-2004 02:42 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 11:03 AM
