The MP3car.com Store
Thread Tools Display Modes
Old 06-19-2004, 02:03 PM   #1
Registered User
Mastero's Avatar
My Photos: (0)
Mastero MK-4.5 12v DC-DC ATX PSU + SDC
Hello Friends.
MK-4.5 is comming soon....
Specification:~
Input
8vdc ~ 30vdc (Can survive a Diesel motor start)
Output
+5vdc @ 12A (max)
+3.3vdc @ 12A (max)
+12vdc @ 10A (max)
+5vstby @ 5A (max)
-5v @ 500MA (max)
-12v @ 500MA (max)
PCB Size: 170mm x 110mm (wont fit standard atx psu case)
Built in shut down controller.
Shall post details soon..
Cheers
Mastero
mastero76@hotmail.com
NEW LINK TO MY SITE ]{*}CYBER SHOP ONLINE{*}
AIRCON UNIT VER 2 IS NOW FOR SALE ]
Life is short enjoy it before it ends.
Mastero is offline   Reply With Quote
Sponsored Links
Old 06-19-2004, 02:48 PM   #2
Raw Wave
rando's CarPC Specs
rando's Avatar
Vehicle: 2004 Toyota 4Runner
My Photos: (0)
Sounds interesting. Keep up the good work!
2004 4runner
rando is offline   Reply With Quote
Old 06-19-2004, 04:54 PM   #3
I see dead kittens
Quattro's Avatar
Vehicle: 1998 Audi A4
My Photos: (0)
250 watts sound impressive. Do you know what the cost might be?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 06-19-2004, 05:36 PM   #4
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Dam 250W that is impressive good work
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-27-2004, 03:50 PM   #5
I see dead kittens
Quattro's Avatar
My Photos: (0)
Mastero,
Just wondering if you had any updates on the MK-4.5
Installed
Old 06-27-2004, 10:01 PM   #6
My Photos: (0)
Is this gonna be another brute force attempt?
By the time you get to a 400W supply the heatsink will need to be about 1 ft x 1ft
MrPerfectionest is offline   Reply With Quote
Old 06-28-2004, 08:10 AM   #7
Registered User
Mastero's Avatar
My Photos: (0)
No there will not be a 400w supply ....
It shall be a while before testing....about a week or two...
Mastero
Old 06-28-2004, 01:17 PM   #8
I see dead kittens
Quattro's Avatar
My Photos: (0)
Thanks for the update. I'm just wating to buy a power supply ans a gps receiver before I start the installation.
Installed
Old 06-28-2004, 01:20 PM   #9
owenjh's Avatar
My Photos: (0)
Wow, nice specifications, how is the shutdown controller going to work? will it be PIC based? also, how will this be avaliable? thru a kit or just schematic?
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Old 06-28-2004, 02:19 PM   #10
MySQL Error
MatrixPC's Avatar
My Photos: (0)
Mastero, just a suggestion for the next PSU.
Can you add another component to the PSU that can send a pulse to turn on the PC. Right now we depend on the mobo that "Resume on power loss" for turn on. Most mobos have that option but there are some mobos don't have that option.
I found the circuit from the12volt.com that use a relay, cap and resistor for constant to pulse.
- Output of the Sproggy relay connect to Pin 86 on image (relay coil +).
- Ground connect to the cap and resistor then to Pin 85 on image (relay coil -) .
- 2 terminal of the ATX power sw can be connected to pin 87 and 30 on image (SPST-NO) pin of the relay.
I tested that circuit on my mobo and it work very well.
Sponsored Links
Old 06-28-2004, 06:14 PM   #11
Registered User
Mastero's Avatar
My Photos: (0)
Matrix i know this cuircut .... i have also tried it works great.
Let me see if i can add a startup also ...
Mastero
Old 06-28-2004, 06:29 PM   #12
Raw Wave
rando's CarPC Specs
rando's Avatar
My Photos: (0)
Cool, it's always good to see you considering more features Mastero. You the man!
BTW, if you use the ignition/ACC signal for the switched +12v lead then wont this circuit send a pulse every time the key is switch from off to on (even if the computer is already on)? Suppose you have a large shutdown delay to keep your pc running during stops at a gas station. When jump back in and restart your car, your computer is going to receive a pulse and start to shut down, isn't it?
2004 4runner
Old 06-28-2004, 07:23 PM   #13
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
How much heat is that PSU going to dissipate?
Cris is offline   Reply With Quote
Old 06-29-2004, 12:32 AM   #14
MySQL Error
MatrixPC's Avatar
My Photos: (0)
Rando, that is true. Everytime you have the IGN/ACC line come hot the circuit send a pulse. That is why on the bottom of my previous post I stated that the (+) to the relay coil is connect to the Sproggy relay output.
Now this got me think more that could also be wrong since the Sproggy relay won't turn on until the power button is "pushed".
The correct place to connect to is the the relay where the output is going to the 5V standby regulator (base on MK4.0) The SDC circuit switch on the relay (STBY Relay) to put the PSU in standby mode thru a 5V regulator chip. The output of the (STBY relay) can connect to the (+) coil of this "power on" relay.
Ok now it should work.
Old 06-29-2004, 12:59 AM   #15
Raw Wave
rando's CarPC Specs
rando's Avatar
My Photos: (0)
Oops, I didn't notice the latter part of your post. With the changes you posted, it makes sense now. Also, it seems like you might be able to ditch the relay in favor of a much smaller and cheaper switching transistor. Small, cheap, powerful and efficient ... it's going to get there!
2004 4runner
Sponsored Links
vB code is On
Trackbacks are Off
Mastero MK-4 ATX PSU with features. Mastero Power Supplies 407 08-23-2006 07:49 PM
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
Mastero MK-4 ATX PSU Semi kit for SALE Mastero Classified Archive 4 06-10-2004 01:42 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 01:07 AM
Has anyone tried modifying a 110v atx PSU to 12v DC? HappyPuppy General Hardware Discussion 15 11-12-2000 10:03 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
