Notices
Old 06-26-2004, 07:41 PM   #1
How much power is needed?
Hi there
In tha fall I will start modifying my car to have in-carpc, I will not be using a seperate display, since the car already has an Alpine CVA-1000R unit that has a nice 5" display - not that big I know, but big enough for me to run my GPS and MP3/DVD at (already running a DVD/MP3 player in the system), previously I have been using a laptop for the GPS but its not that safe to have a loose laptop on the passengerseat.
My intended system is going to be:
MSI KT3 Ultra 2 ATX Motherboard
AMD XP2200 Processor and Fan (not decided yet which)
512 Megs of PC2700 Ram
40-80 GB IDE Harddrive
DVD Rom Drive (might end up be a DVD Writer)
GPS System running on USB
Keyboard running on USB
Trackball Mouse on PS2 port
Radeon 9200 Graphics Card with TV-Out so I can connect it to one of the AUX ports on my Alpine Headunit
Now - have found a lot of info on the different powersupplys available, but will an Opus 150W be sufficient or will it strike out??
Can offcourse run a Invertor, but dont think that is the most optimal solution, my car will be equipped with a dual battery system because of the very highpower amplifier I am putting in so all power that is going to be used in the trunk, Alpine CD Changer, Brain for the unit, amplifier and PC will have a seperate battery.
At this point one of my biggest worries is actually the added weight :-D - Box to host everything will be made of 10mm MDF board, and hopefully a lexan lid so the installation shows, since there is a couple of months to I start actually building system I can plan it real good, for instance already noticed that I had to reverse the installation from first draft in order to use a TV-Out card, planning is good in these projects or am I wrong?
But basic question - how much power is needed?
WhiteWolf
WhiteWolf_DK is offline   Reply With Quote
Old 06-26-2004, 07:44 PM   #2
no1knows's Avatar
planning is good, and the opus SHOULD be fine, try to use laptop dvd/hd drives if possible, laptop dvd slim driv ein the front is always nice. Also, you could get away with half that ram, and probably a lesser processor, unless u intend to run a lot of stuff at once.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
Simple Idea for keeping power to inverter while cranking.... syclone477 Power Supplies 1 03-23-2004 10:03 AM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 06:27 PM
Brief power loss between ACC and start Destin General Hardware Discussion 20 01-26-2001 11:12 PM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
