Notices
Old 06-28-2004, 09:06 AM   #1
binary.h4x's Avatar
GM vehicles and/or Side Post Batteries
Ok, I am starting to throw down my power cables into my new 95 Saturn. This is the first GM vehicle I have owned, and it has a side post battery. So I ordered some of these and now they are on their way to my house. The only question i have is: Do these posts vibrate out of the battery? I would think since they are next to the engine, that they would probably vibrate loose. Would it be recommended to put some LocTite on them, or would that kill condutivity? Any input is appreciated.
binary.h4x is offline   Reply With Quote
Old 06-28-2004, 11:48 AM   #2
Raw Wave
Defiler's Avatar
I've never had an issue with that happening. I have the same type of extended posts in my car and no issues.
/////Alpine PXA-H700
/////Alpine MRV-F345
Aura MR62 (F and R)
Sansa Clip
All wires by Knukonceptz.
My Current MP3s
IamDefiler.com
Still have tons of parts for sale!!!
Defiler is offline   Reply With Quote
Old 06-28-2004, 12:01 PM   #3
owenjh's Avatar
Ouch, I have one of those, it cost me $11 at circuit city, but I needed it then. Mine has never fallen out. I still had power even when I rigged it by sticking it in the plastic cap, and it never did fall out.
CarComputer Status: New Car & Broken (Motherboard Fried)
Owen JH | My Linux Blog | The Tech Fellows
owenjh is offline   Reply With Quote
Old 06-28-2004, 12:08 PM   #4
binary.h4x's Avatar
Thanks guys, thats the kind of reassurance i needed
Old 06-28-2004, 12:08 PM   #5
I have had 3 GM cars/trucks and never had a problem with post coming out. Do not use loctite for it. Also don't try to tighten the post too much or you might brake the post on the battery. You should be fine.
KKDZ28 is offline   Reply With Quote
Old 06-28-2004, 01:49 PM   #6
I had the same type as you show above.
I had one crack and pop off.
But that was only one of many I have used...
-Mario
m3rdpwr is offline   Reply With Quote
Old 06-28-2004, 02:05 PM   #7
binary.h4x's Avatar
m3rdpwr, were you able to use the oem battery connectors with it? For some reason i dont think i will be able to, nor do i think i need the special post if im only going to add one 5/8" ring.
Old 06-28-2004, 02:09 PM   #8
The factory cables would require you to really work the old bolt out. I had aftermarket cables dut to an engine swap.
The bolt you bould still attaches the main starter power cable.
The alternator, amps, and such connect to the smaller bolt which is what broke on mine.
-Mario
Old 06-28-2004, 02:23 PM   #9
owenjh's Avatar
Erm, I got mine in with factory cables, I had to cut the plastic bull-stuff off it i think, or maybe I just jammed it in and tightened up, anyway, it hasn't came out yet, and I know its not stuck in there because I followed the thread, isn't to hard to do really.
Old 06-28-2004, 08:48 PM   #10
eugenen's Avatar
Yep they have been attached to the battery in my 88 s-10 for years, only removed a few times to replace the battery. I have had more problems with the top post terminals, our chrysler would get funky if I didn't clean the terminals every few months (crappy mitsubishi electronics.)
eugenen is offline   Reply With Quote
Old 06-28-2004, 08:57 PM   #11
Top post batteries are notorious for doing that.
Especially if you ever remove the terminals.
They need to be cleaned all the time.
Side post batteries rarely ever have that problem...
On a side note, top post battery cables can be bought pre-made down to 0 gauge. Side post I've never seen thicker pre-made 2-4 gauge...
-Mario
Old 06-28-2004, 09:37 PM   #12
binary.h4x's Avatar
thanks for all the info, i probably will understand it all a bit better when i can actually get under the hood and take the bolts out.
Old 06-28-2004, 09:49 PM   #13
Chairboy's Avatar
On my Buick, I decided against connecting straight to the battery. Instead, I traced the positive wire and found that it ended at a much friendlier bolt at the internal fuse/distribution box. I tied my circuit in right there. It's electrically identical to being hooked straight to the battery, and nothing special was needed. The bolt for the distribution post was long enough that I could put a ring connector in between it and the distribution array.
Chairboy is offline   Reply With Quote
Two batteries in my ride SAScooby Power Supplies 3 05-12-2004 10:15 AM
