Notices
Old 07-18-2004, 04:49 PM   #1
options to hook up inverter?
hi, i m in a process of hooking up my inverter.
I can either wire directly to the battery or use the cigarrete lighter . i understand hard wiring to the battery is better, but is it worth it? drilling a hole on the firewall is alot of work for me. if i use the lighter plug, does it have any disavantages?
I have a 175w inverter. thanks for the help.
PS. the lighter is connected to a 20a fuse.
xtra is offline   Reply With Quote
Old 07-18-2004, 05:22 PM   #2
Blowing the fuse is the biggest disadvantage. I plugged mine into the cigarette lighter then tried to use the lighter...end result= no more audio until I replaced the fuse (at the end of my 45 minute ride to work, good thing I was halfway there when it blew). Next purchase for the car PC...an Opus P/S, power inverter's not worth the hassle for me.
Jailer is offline   Reply With Quote
Old 07-18-2004, 05:24 PM   #3
vcbb5's Avatar
Go to the battery (good clean power is a must). Also, i dought a 175 watt inverter will be powerful enough for the average carputer (again, good clean power is a must).
My Mazda 3s
My Mazda 3s on Car Domain
[||||||||||||||||||--] (90%)
vcbb5 is offline   Reply With Quote
relay, inverter, fuse problems cheesyhoward Power Supplies 5 06-02-2005 10:04 AM
relay, inverter, fuse problems cheesyhoward General Hardware Discussion 6 06-22-2004 04:05 PM
Help Eliminating Inverter Noise - Options prospero General Hardware Discussion 4 04-21-2004 02:37 PM
How do I hook up an inverter? LCDcrazy LCD/Display 7 07-26-2001 03:49 PM
odd inverter behavior jshrieve General Hardware Discussion 30 04-10-2001 05:53 AM
